How to educate users about oneboxing
The discussion revolves around educating users about oneboxing in Discourse. tophee highlights that many new users skip the Discobot tutorial, leading to frequent manual edits to convert links into oneboxes. They propose solutions like editor hints or educational messages. codinghorror agrees with the challenge and suggests personal intervention—such as PMs or public replies explaining edits—as effective methods, noting that public corrections help others learn. elijah supports this approach, emphasizing its real-world learning value. JimPas shares that while most links are now oneboxed, the click counter, which previously showed how many users clicked a link, is missing on oneboxed links. codinghorror tests the counter and confirms it should work, but JimPas clarifies it’s not appearing on their hosted forum. dax identifies that enabling the ‘open links in external tab’ setting resolves the issue, with the click count visible only when clicking the actual link, not the title. JimPas thanks dax for the fix.
If new users do the discobot tutorial, one of the most important things they learn is oneboxing. Unfortunately, few users actually embark on that journey and so I am often editing user posts to turn their links into oneboxes.
I’m assuming that I’m not alone with this and so I’m curious to hear how others are dealing with this. I have this idea of adding some hint to the editor modal for links, but won’t be able to test this before I’m back to my desktop computer next month. Adding an education message could be another option (it could show whenever a user who has never posted a onebox adds a uri to a post).
But maybe people have come up with less technical solutions?
5 Me gusta
Ah yes, the old “you can lead a horse to water, but how do you make it drink?” problem.
No good solution that I can think of, other than personal intervention
  • send a PM letting people know they can do it
  • edit their post which ALSO sends an edit notification, and hope they understand the edit notification
  • edit their post AND send them a PM which is a lot of work
You might also (in a friendly way) call out posts where you’ve edited with a public reply:
Hey great point!
I’ve edited your post to make your link a onebox, by putting it on a line by itself:
http://example.com
This is somewhat better than personal PM intervention (or just a silent edit) since everyone reading it can learn from your edit, etc.
9 Me gusta
This point needs more emphasis. I, for one, am a sponge for learning things called out in that manner.
It is:
  1. A real world usage
  2. A way to improve that situation
  3. Presented right next the problem
I’ve also done the opposite version to people, wherein I defang their unintended onebox by putting whitespace before it and explain what I did and how it helps.
6 Me gusta
A mis usuarios y a mí nos encanta Onebox. Sin embargo, también echamos de menos el número que aparecía en los enlaces individuales para indicar cuántas personas habían hecho clic en ellos. Muy pocos de los enlaces publicados ahora no están en Onebox. Diría que alrededor del 95% lo están. ¡Gracias!
2 Me gusta
Esto debería ocurrir en un onebox, ¿no?
Haz clic en el enlace anterior y veamos si el contador de clics avanza. Es un artículo realmente interesante.
2 Me gusta
Aquí hay una captura de pantalla de un Onebox en el que 4 o 5 miembros hicieron clic. No aparece el número de clics después del enlace.
Edición: Hice clic en tu Onebox y sí, el contador subió de 1 a 2. Simplemente no funciona en nuestro foro.
El recuento de enlaces que no están Oneboxed se está mostrando ahora, al menos en los que he visto recientemente, pero aún no hay recuentos visibles para los enlaces que sí se Oneboxean. Acabo de hacer clic en el enlace Onebox de la captura de pantalla de abajo y no apareció ningún número. Y sé con certeza que varios usuarios también han hecho clic en el enlace. Funciona correctamente aquí en Meta, pero no en nuestro foro (alojado en Discourse). Hasta ahora, nadie se ha quejado en absoluto. Ni siquiera creo que se den cuenta de que debería haber un contador que muestre el número de clics que recibe un enlace.
Habilité la configuration du site pour ouvrir les liens dans un nouvel onglet, et maintenant le nombre de clics est visible
Veuillez noter que vous devez cliquer sur le premier lien (snopes.com) et non sur le titre (Does this photograph...) pour voir le nombre de clics changer.
3 Me gusta
¡Vale, genial! Gracias @dax!
1 me gusta
