How to get admin access when using the Vagrant install?
I’m following this guide to set up a local instance of Discourse using Vagrant:
https://github.com/discourse/discourse/blob/master/docs/VAGRANT.md
It’s working fine, but I don’t see how to give myself admin access.
Maybe this will help:
https://meta.discourse.org/t/create-admin-account-from-console/17274/10?u=sander78
Thank you. This works perfectly. Is there somewhere I can open an issue about adding this to the guide?
You could submit a PR with a line that explains it.
OK → Add instructions for creating an admin account on the CLI to the Vagrant docs by alehandrof · Pull Request #4016 · discourse/discourse · GitHub
The Vagrant install is no longer supported. Check out one of the supported developer environments in #howto:devs.
