I’m working on windows 10.How to install discourse on localhost?
סיכום מבוסס בינה מלאכותית
Installing Discourse on Windows 10
sysdl132 wants to install Discourse on localhost on Windows 10 but encounters errors when running yarn due to connection issues with GitHub.
Falco clarifies that sysdl132 wants to run Discourse locally for testing and development purposes, not as a production website.
Falco provides a guide to install Discourse on Windows 10 for development: https://meta.discourse.org/t/beginners-guide-to-install-discourse-on-windows-10-for-development/75149?u=falco.
sysdl132 follows the guide but gets stuck during the bundle install step, which is slow due to connection issues behind the Great Firewall of China, according to schleifer.
I think I need to use yarn,but there are many errors…
D:\discourse>yarn
yarn install v1.22.0
$ node -e "if(process.env.npm_execpath.indexOf('yarn') === -1) throw new Error('NPM is not supported, please use Yarn instead. ')"
[1/4] Resolving packages...
[2/4] Fetching packages...
[error] Couldn't find match for "1b10552510a1ec13a3d30d46281dc268553ad157" in "refs/heads/9-17-stable,refs/heads/9-18-stable,refs/heads/cli,refs/heads/css_consistency,refs/heads/egor-rogov-tsql,refs/heads/javascript/add-jsdoc,refs/heads/jsdom,refs/heads/master,refs/heads/v10-temp,refs/heads/yyyc514-patch-1,refs/tags/10.0.0-beta.0,refs/tags/5.10,refs/tags/5.11,refs/tags/5.12,refs/tags/5.13,refs/tags/5.14,refs/tags/5.3,refs/tags/5.4,refs/tags/5.5,refs/tags/5.6,refs/tags/5.7,refs/tags/5.8,refs/tags/5.9,refs/tags/6.0,refs/tags/6.0.1,refs/tags/6.0beta,refs/tags/6.1,refs/tags/6.2,refs/tags/7.0,refs/tags/7.0.1,refs/tags/7.1,refs/tags/7.2,refs/tags/7.3,refs/tags/7.4,refs/tags/7.5,refs/tags/8.0,refs/tags/8.0beta,refs/tags/8.1,refs/tags/8.2,refs/tags/8.3,refs/tags/8.4,refs/tags/8.5,refs/tags/8.6,refs/tags/8.7,refs/tags/8.8.0,refs/tags/8.9.0,refs/tags/8.9.1,refs/tags/9.0.0,refs/tags/9.1.0,refs/tags/9.10.0,refs/tags/9.11.0,refs/tags/9.12.0,refs/tags/9.13.0,refs/tags/9.13.1,refs/tags/9.14.0,refs/tags/9.14.1,refs/tags/9.14.2,refs/tags/9.15.0,refs/tags/9.15.1,refs/tags/9.15.10,refs/tags/9.15.2,refs/tags/9.15.3,refs/tags/9.15.4,refs/tags/9.15.5,refs/tags/9.15.6,refs/tags/9.15.7,refs/tags/9.15.8,refs/tags/9.15.9,refs/tags/9.16.0,refs/tags/9.16.1,refs/tags/9.16.2,refs/tags/9.17.0,refs/tags/9.17.1,refs/tags/9.18.0,refs/tags/9.18.1,refs/tags/9.2.0,refs/tags/9.3.0,refs/tags/9.4.0,refs/tags/9.5.0,refs/tags/9.6.0,refs/tags/9.7.0,refs/tags/9.8.0,refs/tags/9.9.0" for "https://github.com/highlightjs/highlight.js".
[info] Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
Do you want a production website for other people to use or something locally on your machine for you to test and develop code?
I only want to try it on localhost(like: http://localhost:3000).
Got it. Follow this guide here: Install Discourse on Windows for development
bundle install is going to download several packages from servers outside the GFW. That will take a long time. Last time I tried from inside it took at least two hours.
You should press [ENTER] when you are done testing.
Thanks for your answer!
