Discourse Installatie Mislukt op Nieuwe Server: FAILED TO BOOTSTRAP
The user katxeus encountered a Discourse installation failure on a fresh Ubuntu 22.04LTS server, with errors including Failure listening on port 6379 and a yarnpkg timeout. Despite checking for port conflicts using lsof and ss, no process was found using port 6379. The issue was eventually resolved by increasing the yarn network timeout, as suggested in a similar thread JammyDodger referenced. Deveroonie also recommended running ./discourse-doctor for diagnosis.
Discourse installation fails on a fresh Ubuntu 22.04LTS Server.
Key take aways seem to be about:
  • Failure listening on port 6379
  • An unexpected error occurred: "https://registry.yarnpkg.com/rxjs/-/rxjs-6.6.3.tgz: ESOCKETTIMEDOUT".
  • [3/5] Fetching packages... info There appears to be trouble with your network connection. Retrying...
The rest of the console log is here:
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
2.0.20230502-0058: Pulling from discourse/base
Digest: sha256:fa95da36c3d3a582d644b139ec678f5778d745697454bc86f598c689031b30aa
Status: Image is up to date for discourse/base:2.0.20230502-0058
docker.io/discourse/base:2.0.20230502-0058
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-05-07T12:05:04.539866 #1]  INFO -- : Reading from stdin
I, [2023-05-07T12:05:04.546394 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-05-07T12:05:04.660188 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-05-07T12:05:04.660484 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-05-07T12:05:04.673331 #1]  INFO -- :
I, [2023-05-07T12:05:04.675066 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-05-07T12:05:04.680819 #1]  INFO -- :
I, [2023-05-07T12:05:04.681490 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-05-07T12:05:04.686777 #1]  INFO -- :
I, [2023-05-07T12:05:04.687466 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-05-07T12:05:04.692307 #1]  INFO -- :
I, [2023-05-07T12:05:04.693228 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-05-07T12:05:04.699774 #1]  INFO -- :
I, [2023-05-07T12:05:04.700295 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/05/07 12:05:04 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-05-07T12:05:04.744608 #1]  INFO -- :
I, [2023-05-07T12:05:04.745030 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-05-07T12:05:04.749765 #1]  INFO -- :
I, [2023-05-07T12:05:04.750379 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-05-07T12:05:04.754536 #1]  INFO -- :
I, [2023-05-07T12:05:04.755124 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-05-07T12:05:04.758496 #1]  INFO -- :
I, [2023-05-07T12:05:04.759056 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-05-07T12:05:04.762381 #1]  INFO -- :
I, [2023-05-07T12:05:04.771096 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-05-07T12:05:04.777848 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-05-07T12:05:04.785193 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-05-07T12:05:04.791975 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-05-07T12:05:04.792769 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-05-07T12:05:07.919753 #1]  INFO -- :
I, [2023-05-07T12:05:07.920641 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-05-07T12:05:07.924131 #1]  INFO -- :
I, [2023-05-07T12:05:07.924453 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-05-07T12:05:07.961773 #1]  INFO -- :
I, [2023-05-07T12:05:07.962051 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-05-07T12:05:07.966111 #1]  INFO -- :
I, [2023-05-07T12:05:07.966677 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-05-07T12:05:07.977176 #1]  INFO -- :
I, [2023-05-07T12:05:07.977871 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-05-07T12:05:07.981532 #1]  INFO -- :
I, [2023-05-07T12:05:07.984567 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.985718 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.986774 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.988037 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.989187 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.990294 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:07.991276 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-05-07T12:05:08.001041 #1]  INFO -- :
I, [2023-05-07T12:05:08.002071 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:08.002762 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:08.003976 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-05-07T12:05:08.005775 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-05-07T12:05:08.006438 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-05-07T12:05:08.007408 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-05-07T12:05:08.008275 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-05-07T12:05:08.011213 #1]  INFO -- : > sleep 5
2023-05-07 12:05:08.251 UTC [41] LOG:  starting PostgreSQL 13.10 (Debian 13.10-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-05-07 12:05:08.252 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-05-07 12:05:08.252 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2023-05-07 12:05:08.257 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-05-07 12:05:08.267 UTC [44] LOG:  database system was shut down at 2023-05-07 11:31:27 UTC
2023-05-07 12:05:08.292 UTC [41] LOG:  database system is ready to accept connections
I, [2023-05-07T12:05:13.016044 #1]  INFO -- :
I, [2023-05-07T12:05:13.016840 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2023-05-07 12:05:13.195 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2023-05-07 12:05:13.195 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2023-05-07T12:05:13.198892 #1]  INFO -- :
I, [2023-05-07T12:05:13.199959 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-05-07 12:05:13.299 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2023-05-07 12:05:13.299 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2023-05-07T12:05:13.303279 #1]  INFO -- :
I, [2023-05-07T12:05:13.304125 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-05-07T12:05:13.369204 #1]  INFO -- : GRANT
I, [2023-05-07T12:05:13.370352 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-05-07T12:05:13.433857 #1]  INFO -- : ALTER SCHEMA
I, [2023-05-07T12:05:13.434726 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2023-05-07T12:05:13.524487 #1]  INFO -- : CREATE EXTENSION
I, [2023-05-07T12:05:13.525343 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2023-05-07T12:05:13.585308 #1]  INFO -- : CREATE EXTENSION
I, [2023-05-07T12:05:13.586144 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-05-07T12:05:13.650563 #1]  INFO -- : CREATE EXTENSION
I, [2023-05-07T12:05:13.651460 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-05-07T12:05:13.712661 #1]  INFO -- : CREATE EXTENSION
I, [2023-05-07T12:05:13.713840 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2023-05-07T12:05:13.718676 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-05-07T12:05:13.831609 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2023-05-07T12:05:13.838446 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2023-05-07T12:05:13.838982 #1]  INFO -- : > echo postgres installed!
I, [2023-05-07T12:05:13.843636 #1]  INFO -- : postgres installed!
I, [2023-05-07T12:05:13.851509 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2023-05-07T12:05:13.858957 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2023-05-07T12:05:13.866173 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2023-05-07T12:05:13.868786 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.870105 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.874328 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-05-07T12:05:13.878984 #1]  INFO -- :
I, [2023-05-07T12:05:13.879788 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.880785 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.882834 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.884793 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.886745 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-05-07T12:05:13.889097 #1]  INFO -- : > echo redis installed
I, [2023-05-07T12:05:13.893105 #1]  INFO -- : redis installed
I, [2023-05-07T12:05:13.893576 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-05-07T12:05:13.904492 #1]  INFO -- : logfile ""
I, [2023-05-07T12:05:13.905209 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-05-07T12:05:13.908499 #1]  INFO -- : > sleep 10
102:C 07 May 2023 12:05:13.933 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
102:C 07 May 2023 12:05:13.933 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=102, just started
102:C 07 May 2023 12:05:13.934 # Configuration loaded
102:M 07 May 2023 12:05:13.935 * monotonic clock: POSIX clock_gettime
102:M 07 May 2023 12:05:13.938 * Running mode=standalone, port=6379.
102:M 07 May 2023 12:05:13.939 # Server initialized
102:M 07 May 2023 12:05:13.942 * Loading RDB produced by version 7.0.7
102:M 07 May 2023 12:05:13.943 * RDB age 2026 seconds
102:M 07 May 2023 12:05:13.943 * RDB memory usage when created 0.82 Mb
102:M 07 May 2023 12:05:13.943 * Done loading RDB, keys loaded: 0, keys expired: 0.
102:M 07 May 2023 12:05:13.943 * DB loaded from disk: 0.001 seconds
102:M 07 May 2023 12:05:13.943 * Ready to accept connections
I, [2023-05-07T12:05:23.912749 #1]  INFO -- :
I, [2023-05-07T12:05:23.913589 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-05-07T12:05:23.920284 #1]  INFO -- : thpoff is installed!
I, [2023-05-07T12:05:23.920874 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-05-07T12:05:24.024728 #1]  INFO -- :
I, [2023-05-07T12:05:24.025539 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-05-07T12:05:24.128182 #1]  INFO -- :
I, [2023-05-07T12:05:24.128880 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-05-07T12:05:24.214528 #1]  INFO -- :
I, [2023-05-07T12:05:24.215194 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-05-07T12:05:24.220322 #1]  INFO -- :
I, [2023-05-07T12:05:24.225112 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2023-05-07T12:05:24.233974 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2023-05-07T12:05:24.241775 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2023-05-07T12:05:24.249185 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2023-05-07T12:05:24.256657 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2023-05-07T12:05:24.264098 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2023-05-07T12:05:24.264712 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-05-07T12:05:24.265389 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-05-07T12:05:24.269969 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
129:C 07 May 2023 12:05:24.279 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
129:C 07 May 2023 12:05:24.280 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=129, just started
129:C 07 May 2023 12:05:24.280 # Configuration loaded
129:M 07 May 2023 12:05:24.281 * monotonic clock: POSIX clock_gettime
129:M 07 May 2023 12:05:24.282 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
129:M 07 May 2023 12:05:24.282 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33085/33085), done.
I, [2023-05-07T12:05:31.780874 #1]  INFO -- : HEAD is now at a8e28060d FIX: rename notify_about_flags_after to notify_about_reviewable_item_after (#21320)
I, [2023-05-07T12:05:31.787251 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-05-07T12:05:32.101166 #1]  INFO -- :
I, [2023-05-07T12:05:32.101553 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/a11y-select-kit-close-on-focus-out
 - [deleted]             (none)     -> origin/app-inject
 - [deleted]             (none)     -> origin/bump-eslint
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/babel/core-7.21.5
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/babel/standalone-7.21.7
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/jsdom-21.1.2
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.1.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.2.0
 - [deleted]             (none)     -> origin/dev_fix_test
 - [deleted]             (none)     -> origin/feature_notification_admin_problems
 - [deleted]             (none)     -> origin/fix-username-validation
 - [deleted]             (none)     -> origin/loic-set-limits-for-reviewables
 - [deleted]             (none)     -> origin/old-styles
   a8e28060d..83f1a1337  main                   -> origin/main
 * [new branch]          0-fix-inj              -> origin/0-fix-inj
 + e5efacf69...b3cfecbd9 default-to-subcategory-on-read-only-categories -> origin/default-to-subcategory-on-read-only-categories  (forced update)
 * [new branch]          dependabot/bundler/rspec-rails-6.0.2 -> origin/dependabot/bundler/rspec-rails-6.0.2
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/jsdom-22.0.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/jsdom-22.0.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.1.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.1.1
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.3.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.3.0
 + b8e4996b9...f16673f79 dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.2.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.2.0  (forced update)
 + 3ed9e6173...4ae8c98dd dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.3.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.3.0  (forced update)
 + 3bb7b79f0...8e7c9354f dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.2.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.2.0  (forced update)
   43bbc443c..0532a1c3d  dev-new-user-menu-default-enable -> origin/dev-new-user-menu-default-enable
 * [new branch]          dev/delete-old-personal-message-settings -> origin/dev/delete-old-personal-message-settings
 + 895956cb1...10ea7a4f0 ember-this-fallback    -> origin/ember-this-fallback  (forced update)
   10dda035f..4838c2950  feature/add-user-status-to-inline-mentions-on-chat -> origin/feature/add-user-status-to-inline-mentions-on-chat
 * [new branch]          feature/add-user-status-to-inline-mentions-on-chat-in-progress -> origin/feature/add-user-status-to-inline-mentions-on-chat-in-progress
 * [new branch]          feature/status-on-mentions-on-updated-chat-messages -> origin/feature/status-on-mentions-on-updated-chat-messages
 * [new branch]          feature_user_tips      -> origin/feature_user_tips
 * [new branch]          fix-select-kit-click-outside-regression -> origin/fix-select-kit-click-outside-regression
 * [new branch]          fix-tests              -> origin/fix-tests
 * [new branch]          fix_inactive_user_card -> origin/fix_inactive_user_card
 * [new branch]          fix_utf8               -> origin/fix_utf8
 + 4e8828636...c7ddb4f19 generic-import         -> origin/generic-import  (forced update)
 + 0eeb01892...f5f7e58fa headless-new           -> origin/headless-new  (forced update)
 * [new branch]          implicit-injections-v2 -> origin/implicit-injections-v2
 + ec1a0d83f...99f0e8336 modal-named-outlet     -> origin/modal-named-outlet  (forced update)
 * [new branch]          offline-app-testing    -> origin/offline-app-testing
 * [new branch]          sk-loading-slider      -> origin/sk-loading-slider
 * [new branch]          sk-tab-accessibility   -> origin/sk-tab-accessibility
   845000a6c..784006c71  stable                 -> origin/stable
 * [new branch]          tag-displayName        -> origin/tag-displayName
   a8e28060d..83f1a1337  tests-passed           -> origin/tests-passed
 * [new branch]          try-buildjet           -> origin/try-buildjet
 + 42b7246b2...bf6c559f0 ux_welcome_topic       -> origin/ux_welcome_topic  (forced update)
I, [2023-05-07T12:05:33.186706 #1]  INFO -- :
I, [2023-05-07T12:05:33.186868 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2023-05-07T12:05:36.080520 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-05-07T12:05:36.080829 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2023-05-07T12:05:36.096347 #1]  INFO -- :
I, [2023-05-07T12:05:36.096581 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-05-07T12:05:36.105434 #1]  INFO -- :
I, [2023-05-07T12:05:36.106059 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-05-07T12:05:36.113771 #1]  INFO -- :
I, [2023-05-07T12:05:36.114176 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-05-07T12:05:36.120498 #1]  INFO -- :
I, [2023-05-07T12:05:36.120790 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-05-07T12:05:36.126361 #1]  INFO -- :
I, [2023-05-07T12:05:36.126640 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-05-07T12:05:36.134332 #1]  INFO -- :
I, [2023-05-07T12:05:36.135232 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2023-05-07T12:05:36.142282 #1]  INFO -- :
I, [2023-05-07T12:05:36.142556 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-05-07T12:05:36.150458 #1]  INFO -- :
I, [2023-05-07T12:05:36.151397 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-05-07T12:05:36.161418 #1]  INFO -- :
I, [2023-05-07T12:05:36.161726 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2023-05-07T12:05:36.170099 #1]  INFO -- :
I, [2023-05-07T12:05:36.170386 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-05-07T12:05:36.178000 #1]  INFO -- :
I, [2023-05-07T12:05:36.178190 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2023-05-07T12:05:36.187455 #1]  INFO -- :
I, [2023-05-07T12:05:36.188202 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-05-07T12:05:36.196355 #1]  INFO -- :
I, [2023-05-07T12:05:36.196836 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-05-07T12:05:36.206318 #1]  INFO -- :
I, [2023-05-07T12:05:36.207087 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-05-07T12:05:36.221070 #1]  INFO -- :
I, [2023-05-07T12:05:36.226051 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-05-07T12:05:36.228290 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-05-07T12:05:37.388848 #1]  INFO -- :
I, [2023-05-07T12:05:37.389813 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-05-07T12:05:37.403667 #1]  INFO -- :
I, [2023-05-07T12:05:37.404633 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-05-07T12:05:37.411650 #1]  INFO -- :
I, [2023-05-07T12:05:37.412393 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2023-05-07T12:05:37.419873 #1]  INFO -- :
I, [2023-05-07T12:05:37.421273 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-05-07T12:05:37.426051 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-05-07T12:05:37.426830 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-05-07T12:05:37.427685 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-05-07T12:05:37.428721 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-05-07T12:05:37.429212 #1]  INFO -- : > echo "done configuring web"
I, [2023-05-07T12:05:37.432836 #1]  INFO -- : done configuring web
I, [2023-05-07T12:05:37.433619 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-05-07T12:05:38.745410 #1]  INFO -- : Successfully installed bundler-2.4.4
1 gem installed
I, [2023-05-07T12:05:38.745689 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-05-07T12:05:56.767639 #1]  INFO -- :
I, [2023-05-07T12:05:56.770274 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
error An unexpected error occurred: "https://registry.yarnpkg.com/rxjs/-/rxjs-6.6.3.tgz: ESOCKETTIMEDOUT".
I, [2023-05-07T12:09:42.395368 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
info If you think this is a bug, please open a bug report with the information provided in "/var/www/discourse/yarn-error.log".
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
I, [2023-05-07T12:09:42.413716 #1]  INFO -- : Terminating async processes
I, [2023-05-07T12:09:42.414196 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2023-05-07T12:09:42.414362 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
2023-05-07 12:09:42.415 UTC [41] LOG:  received fast shutdown request
102:signal-handler (1683461382) Received SIGTERM scheduling shutdown...
2023-05-07 12:09:42.427 UTC [41] LOG:  aborting any active transactions
102:M 07 May 2023 12:09:42.612 # User requested shutdown...
102:M 07 May 2023 12:09:42.614 * Saving the final RDB snapshot before exiting.
2023-05-07 12:09:42.616 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
102:M 07 May 2023 12:09:42.626 * DB saved on disk
2023-05-07 12:09:42.627 UTC [45] LOG:  shutting down
102:M 07 May 2023 12:09:42.627 # Redis is now ready to exit, bye bye...
2023-05-07 12:09:42.888 UTC [41] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' failed with return #<Process::Status: pid 276 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "cmd"=>["su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
f11564bffffe2d23984c42620c8ce6a456fc623ab6ac8093558b981522fd76fe
Thanks
Run lsof -i:6379… To see what is running on it
Thanks let me try that and get back
I returns nothing unfortunately.
Also read answers from here: Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
But it also doesn’t solve the issue
But atleast according to
port 80 or 443 are free
root@wims-collaboration-instance:/var/discourse# sudo lsof -i -P -n
COMMAND    PID            USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
systemd-n  403 systemd-network   15u  IPv4  44356      0t0  UDP 10.128.0.5:68
systemd-r  405 systemd-resolve   13u  IPv4  15076      0t0  UDP 127.0.0.53:53
systemd-r  405 systemd-resolve   14u  IPv4  15077      0t0  TCP 127.0.0.53:53 (LISTEN)
chronyd    450         _chrony    5u  IPv4  15241      0t0  UDP 127.0.0.1:323
chronyd    450         _chrony    6u  IPv6  15242      0t0  UDP [::1]:323
google_os  451            root    3u  IPv4  15296      0t0  TCP 10.128.0.5:42794->169.254.169.254:80 (ESTABLISHED)
google_os  451            root    8u  IPv4  53026      0t0  TCP 10.128.0.5:43566->216.239.34.174:443 (ESTABLISHED)
google_gu  510            root    6u  IPv4  50869      0t0  TCP 10.128.0.5:43170->216.239.36.174:443 (ESTABLISHED)
google_gu  510            root    9u  IPv4  17759      0t0  TCP 10.128.0.5:50528->169.254.169.254:80 (ESTABLISHED)
sshd       725            root    3u  IPv4  17765      0t0  TCP *:22 (LISTEN)
sshd       725            root    4u  IPv6  17767      0t0  TCP *:22 (LISTEN)
sshd      6527            root    4u  IPv4  42936      0t0  TCP 10.128.0.5:22->35.235.244.33:34847 (ESTABLISHED)
sshd      6612   james_katwere    4u  IPv4  42936      0t0  TCP 10.128.0.5:22->35.235.244.33:34847 (ESTABLISHED)
And port 6379 doesn’t seem to be among those being listened to either.
root@wims-collaboration-instance:/var/discourse# ss -tulw
Netid     State      Recv-Q     Send-Q           Local Address:Port               Peer Address:Port     Process
icmp6     UNCONN     0          0                       *%ens4:ipv6-icmp                     *:*
udp       UNCONN     0          0              10.128.0.5%ens4:bootpc                  0.0.0.0:*
udp       UNCONN     0          0                    127.0.0.1:323                     0.0.0.0:*
udp       UNCONN     0          0                127.0.0.53%lo:domain                  0.0.0.0:*
udp       UNCONN     0          0                        [::1]:323                        [::]:*
tcp       LISTEN     0          4096             127.0.0.53%lo:domain                  0.0.0.0:*
tcp       LISTEN     0          128                    0.0.0.0:ssh                     0.0.0.0:*
tcp       LISTEN     0          128                       [::]:ssh                        [::]:*
try running ./discourse-doctor
There was a similar error in this topic Stuck on yarn install, Time out - #2 by agungor, and they had some success with increasing the yarn network timeout, if that’s any help?
Thanks am going to check it out. Hope it helps
I tried but it wasn’t any different from the main logs
oh that isn’t helpful!
Thanks, I did follow the instructions and the solution did solve my problem. Thanks again
