Please help. if I have exited anonymous , how can I comment(reply) with that anonymous name?
How long ago did you create the anonymous account?
Thanks.
the time I set for :
anonymous account duration minutes is 120 minutes (2 hours). In these 2 hours I reply with anonymous1, and the 2 hour time ends, I use anonymous2, now all my replies will be anonymous2 (but I don’t want this to happen), I want to reply with anonymous1.
How can I reply to anonymous1 (at this point, I created anonymous2, then I go out of anonymous2 back to the original user)
First you should change that timeframe to something more suitable for you. 2 hours is defenetly too short in the future, so use something longer — one month, a year…
The easiest way to change to anonymous1 is find it from user directory, open its profile and then act as it. Sure — you have to do that route everytime, but how long would that topic be alive?
Can you explain more: Once I exited anonymous1 (and anonymous1 timed out, and now if I create a new anonymous, it will be anonymous2). How can I Reply with anonymous1
Go to admin > users, search anonymous1 and open that profile. Show public profile and from there open admin-menu. Scroll down and click impersonate. That’s it.
If you aren’t an admin there is absolut nothing you can do.
Thanks for your answer, I will do your operation.
