Comment rendre le délai de verrouillage automatique plus précis ?
Is there a way to make the times in the text that appears for auto-locking more detailed?
Right now it’ll say something like this:
How could I go about making it say days + hours when > 24 hours and hours + minutes otherwise instead? Will this need a plugin or a theme component?
Thanks!
Can’t you hover your pointing device over the date to see the exact time?
I just tried it on my instance and I don’t think so.
Is there a topic on meta I can see that work on?
If it does not, we should make sure the detailed HTML title tag is present on the time for hovering devices. Cc @j.jaffeux
Ok I went with “easy” solution and date only:
https://github.com/discourse/discourse/commit/0bd480c60035aae211abbf75b549c5464c22655d
Think that should be enough.
Thanks! That works great for desktop! I do wish there was also some way to see it on mobile though.
