How to make unindexed articles?
Hi..If I want to create an unindexed article which is visible when one has the link & is not visible on my homepage. Is this possible?? Please help
as a staff member, one can set a topic as unlisted which should serve the purpose.
Hi ..Thank you, I will try this. Hope this works.
Hi Bhanu..thanks a ton..it works :slight_smile:
