Hoe de bovenste menubalk van links naar rechts te verplaatsen
Is it possible to move the top menu bar from left to right?
You can see that the top menu bar is currently on the left side, similar to discourse. But we want to change that menu bar.
Our official website is here
Following is a snapshot where you can take a look:
This is exactly what we require.
Thank you.
Hello,
That is possible to switch back to the old navigation menu with the navigation menu site setting.
Go to /admin/site_settings/category/navigation
Admin > Settings > Navigation
or search for navigation menu
Select the Legacy option on navigation menu
Without you and your support, I wouldn’t have been able to get through this. Thank you for your kindness and support!
