Hey, I’d like to pin the GENERAL category on top.
How can I do this?
Here’s a screenshot. Now it appears on the very bottom as I added it last.
Thanks,
Vessy
You can’t pin a single category, but you can manually order all categories.
To do this you need to go to admin > settings and enable fixed category positions
Then from your category page, you can select reorder categories from this menu on the right
