How to replace/override homepage template
I would like to configure different custom homepages for logged-in and non-logged-in users. While I am aware that this can be implemented using JavaScript, I am interested in knowing whether it can also be achieved through a Discourse component or plugin.
I have come across the component User-specific Discourse home page, which allows creating a new route and adding a template, but I would prefer not to use that approach.
If there are any alternative suggestions or recommended best practices, I would greatly appreciate your guidance.
A discourse component is written in JavaScript :wink:
There is custom home page support for developers and you could differentiate between those types of users.
Thank you for your response. I tried the approach mentioned in the GitHub repository by adding "custom-homepage": true to the about.json file of my theme, but it does not seem to be working. Could you please confirm if this is the correct method?
I suggest opening a topic in Dev
If you are struggling consider hiring a seasoned Discourse developer in Marketplace
It’s the correct method, have you followed all of the steps? after adding
  "modifiers": {
    "custom_homepage": "true"
and enabling your theme, do you see this as your homepage?
Yes, I followed the steps given in thread. Specifically, I first added "custom-homepage": "true" in the modifiers, and then I created a component at javascripts/discourse/connectors/custom-homepage/home.gjs.
do you still see the default homepage? or do you see a blank homepage? are there any console errors?
Yes, I see my default homepage and no errors in console
You probably need to change this setting:
in preferences
Now i got it i have to set Default Home Page to default then it worked
Thank You for your response it worked i just needed to set Default Home Page setting to default.
This topic was automatically closed 30 minutes after the last reply. New replies are no longer allowed.
