Has anyone successfully setup Discourse running on an Apache vhost, instead of the default nginx?
It looks like most of the chatter around apache on these forums is about running Discourse on a host that already runs apache. In every case that I’ve seen, people just proxy apache back to nginx. To be clear: I want the docker backend container running Discourse to run the virtual host in Apache, not Nginx.
Specifically, I’m hoping to run the Discourse backend in Apache instead of Nginx to enable mod_security. Setting up Nginx with mod_security requires compiling Nginx from source–a complexity I’d like to avoid.
My current production server is already running several sites (wordpress, mediawiki, etc). We use Nginx to terminate https and do some basic DOS rate limiting → varnish cache → apache backend with mod_security. If possible, I’d like to keep this architecture for Discourse – with the backend Discourse docker container running Apache with mod_security, not Nginx.
Has anyone successfully setup Discourse to run in Apache?
Sorry, I’m new to docker. I’m really struggling to find how the ‘/etc/nginx/conf.d/discourse.conf’ file is even put in-place on the docker container. Can someone elucidate the steps for how that file is generated and put in-place on the container by the ‘./launcher’ script?
EDIT: wait, is nginx already being compiled from source by Discourse?
No they have not. Discourse is rather tightly connected with nginx. It will be difficult if impossible to replace it with apache. And since you’ll be the only person doing that, no one else will care when it breaks.
Just use the docker container that everyone on the planet uses and stick apache in front of it if you think that’ll help security somehow.
So it looks like /etc/nginx/conf.d/discourse.conf is generated on the container by the template file /var/docker/templates/web.template.yml – which copies it in-place from $home/config/nginx.sample.conf, and then makes changes with the replace yaml blocks (which is further updated in subsequent templates, such as templates/web.socketed.template.yml).
I was assuming that the nginx.sample.conf file was just installed in-place by nginx when compiling from source in image/base/install-nginx, but the only nginx.sample.conf file I found on the container (/var/www/discourse/config/nginx.sample.conf) already had discourse-specific directives in it.
I’d rather not have nginx → varnish → apache → nginx
To be clear: do you think it would be safer for me to update the ‘image/base/install-nginx’ script to compile nginx on the Discourse docker container with mod_security support rather than update the container to run the Discourse vhost behind apache (as opposed to Nginx)? If so, what are the risks of me modifying the install-nginx script? How could it break my Discourse install in the future?
PSA: Everything you are proposing to do, while technically feasible is completely unsupported. We can’t reasonably support every possible combination people come up with to serve Discourse on the web. So the support here on this forums are restricted to installs following the discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub guide.
I resolved setting app.yml (Discouse) like so: expose: - "2045:80" # http - "8443:443" # https
.. and my vhost like so: <VirtualHost *myhostIP*:443> ServerName forum.domain.org ServerAlias forum.domain.org
… ProxyAddHeaders Off ProxyPass / "http://localhost:2045/" ProxyPassReverse / "http://localhost:2045/" </VirtualHost>
@ledimeo That’s what @pfaffman suggested, and what I think would be better in this case, to not break things badly in the future when new versions are released. But it seems that he already uses another nginx at the front as a reverse proxy and don’t want:
That said, I think that proxing apache to nginx (even if it would end up with those 4 layers) would at least be more maintainable than trying to change the way discourse works in the official installation.
So adding apache as a proxy to the Discourse nginx is definitely an option.
I agree that a pro would be making future upgrades easier, and that’s an important point.
But adding another hop to the architecture would not only make debugging issues in the future more complex – I also have concerns about Apache’s performance as a proxy to a web application that uses long polling, as pointed out by @sam in this post from 2016.
I generally prefer nginx to apache, except when it comes to mod_security. It would be fantastic if the OS repos included packages to enable mod_security in nginx like they do for Apache, but currently enabling mod_security on nginx requires compiling nginx from source in both RHEL/Cent and Debian. And I avoid depending on packages compiled from source on production like the plague..
related: I’ve been poking around with the install-nginx script, and I found a minor logic error: the cleanup line that’s supposed to delete the nginx source from /tmp/ actually doesn’t do anything.
There is no /tmp/nginx/ directory: it’s /tmp/nginx-$VERSION/ (at the moment it’s /tmp/nginx-1.17.4/ and there’s also the tarball /tmp/nginx-1.17.4.tar.gz).
Unfortunately, my updated /var/discourse/image/base/install-nginx script does not appear to be executed when I run a /var/discourse/launcher destroy app && /var/discourse/launcher/rebuild app.
Is there any reason this rebuild command would not re-execute the updated install-nginx script?
If you aren’t familiar with Docker this is going to be a hard path…
discourse_docker contains the source code for our base docker image that lives in the public Docker registry, and that will never be run locally and the whole reason is having a reusable image.
ok. Well, I lied about vim for simplicity. I’m actually running these commands to idempotently & robustly update the script
cd /var/discourse/image/base
cp install-nginx install-nginx.`date "+%Y%m%d_%H%M%S"`.orig
# add a block to checkout the the modsecurity nginx module just before downloading the nginx source
grep 'ModSecurity' install-nginx || sed -i 's%\(curl.*nginx\.org/download.*\)%# mod_security --maltfield\napt-get install -y libmodsecurity-dev modsecurity-crs\ncd /tmp\ngit clone --depth 1 https://github.com/SpiderLabs/ModSecurity-nginx.git\n\n\1%' install-nginx
# update the configure line to include the ModSecurity module checked-out above
sed -i '/ModSecurity/! s%^[^#]*./configure \(.*nginx.*\)%#./configure \1\n./configure \1 --add-module=/tmp/ModSecurity-nginx%' install-nginx
# add a line to cleanup section
grep 'rm -fr /tmp/ModSecurity-nginx' install-nginx || sed -i 's%\(rm -fr.*/tmp/nginx.*\)%rm -fr /tmp/ModSecurity-nginx\n\1%' install-nginx
Where should I put these commands so that the actualinstall-nginx script used by the container on bootstrap is modified?
