How to skip override-overrided localizations
I wonder how I can stop Discourse from overriding my already overridden translations. Our UI/UX is a little customized and it does not follow the current one in Discourse as is.
In Spanish, some people do not understand this Activar listas inteligentes al escribir en el compositor but Listas automáticas al escribir mensajes, and the same with a lot of strings.
I found myself editing texts more than three times because the main branch was updated. Previously, I was able to discard the ‘new’ translations, but for months now they always overwrite mine.
I’m open to suggestions, workarounds, or looking into the admin config that I need to check out. Thanks :slight_smile:
how are you editing them? typically translations strings shouldn’t be overridden with an update if you’re editing them from /admin/customize/site_texts
I’m editing on this admin path, and they started to be overridden a couple of months ago. I can’t remember an exact date, but they weren’t being overridden for years.
Strange… was the example you mentioned, Activar listas inteligentes al escribir en el compositor one of the strings that’s repeatedly having the issue?
Every string that is updated (from core) reverts to default.
I hope to find a solution; it’s really hard to maintain. I can debug and test whatever is needed.
OK, I think I understand that it only happens in the strings I update before Discourse publishes its translations.
If I change Cancel (Resenha) to cancelar, when Discourse publishes the translation, my initial string is lost.
Are you saying that for (probably new) strings that don’t yet have a Spanish translation, you create one and then it gets overridden when they get around to adding the Spanish string? If so, (without looking at the code) it makes sense that it would insert the new string and ignore yours, though that could well be considered a bug (I can see arguments for both ways, however).
That’s exactly what happens here. I don’t know if consider it a bug, but rather something need to be careful about.
I mean, translating all the untranslated experimental stuff takes up our time, and a simple update just discards all of it instantly.
Why don’t you spend that time on translating Discourse for everyone?
The plain truth: because I’m translating slangs, avoiding a lot of rules on purpose… And the translation system that Discourse uses was a little intimidating.
If we’re still here in a couple of months or years, I will put my effort into translating to Esperanto.
I hope we can count on more simple tools :slight_smile:
