Hi,
I somehow managed to turn on a “latest topics” / “view latest topics” section on my site’s homepage, and I can’t find where to turn it off.
Could I ask for some advice?
Thank you!
Welcome to Meta ![]()
Is that heading also visible in safe mode?
To me, it looks like the heading that should be hidden except for screen readers, which was added in
https://github.com/discourse/discourse/pull/32422
Edit: I was wrong
It doesn’t seem to have helped. I have it set up like this here…
The problem doesn’t appear in safe mode.
Did you add any customizations recently?
As a first step, you can check if the cause is a plugin or theme (component) by disabling only one of them. And then disable them one by one.
Is your forum public?
It looks like we have a winner. I’ll need to adjust the settings."
