Hoe gebruik je lettertypen die niet in discourse aanwezig zijn?
I used a Twitter font in Discourse, through a CSS code, but in some browsers the font doesn’t work and in others it works, why?
Can you share your CSS code, and tell us in which browser the font doesn’t load?
Ideally, can you share a link to your forum?
I would recommend checking out Google fonts Customization > Theme component for ease of use. Will grab a link.
it is one quick easy solution depending on your needs
