Okay, could you try running the post-create-listener of Babble to see if that fixes it?
Oh excellent, that did it, thank you! I can confirm that posts are coming up as expected now.
Okay, I’ve merged that branch into master now, and bumped the version, so this should work in Babble from now on. ![]()
I am confused about what is the best method to create the discourse user accounts for bots!
I would like to make several accounts similar to discobot that don’t have a valid email address and are dedicated for API use, is there a commandline way to do that? “rake admin:create” sanity checks the email address before creating the user.
Our environment has SSO enabled against a windows AD and I would rather not have to create extra domain users and exchange accounts just to get some spare email addresses for my bot accounts ![]()
You can create them with any (non conflicting) email from that rake task, since they will not be authenticating against your sso.
You would most likely want to turn off the email notifications in the bot profile just so no email is ever attempted to get sent there too.
Does the bot only reply if the post begins with “@hubot”? I’d like to be able to have a complete message and then use bot commands at the bottom of the message. Something like:
I swing my giant axe and it comes down on the goblin!
@hubot roll 1d20+3
But I’m not getting a response unless I’m referencing the bot in the first word.
That’s the difference between robot.respond and robot.hear – you can use the latter to catch expressions like roll {thing}. If you don’t mind reading coffeescript, you can read my dice roller implementation here.
This is exactly what I need. Thanks for the response!
Need help installing this adapter. Do I install this on the server. As in do I ssh in, move to /var/discourse and then follow the instructions as mentioned in the github link?
Hubot can be installed completely separate from your discourse instance. You may install it on the same server as your running Discourse, but it is not necessary to do so.
All that’s needed is an API key, through which the bot communicates with the Discourse instance.
The Hubot adapter to talk to Discourse is installed alongside the Hubot instance when you’re setting it up.
I’ve got Hubot up and running like a champ – so thank you for the guidance here!
Is there a way to have the bot automatically follow all categories? Currently, we’re having to go and manually add the categories.
Any help is greatly appreciated!
Thanks for the feedback - there’s no way to currently let the bot follow all categories automatically unfortunately. It does seem like a decent candidate for a configurable option though.
I consider it a nice to have though, since it shouldn’t be too much effort to sign in as the bot and set categories (depending on the number of categories!).
Thank you for the response! It’s that last bit that gets us. We utilize Discourse for an enterprise that has 100+ individual activities, hundreds of managers, and thousands of users.
As the platform grows, it becomes a pain to track and update Hubot to follow. It’d be nice if there were a group option that once assigned to, the user (or bot) automatically follows all.
Again, thank you!
J’essaie de trouver des détails sur ce plugin… mais seulement des bribes…
Existe-t-il un plugin qui active un bot de type ChatGPT, mais qui est adapté au thème/sujet du forum ?
Par exemple, j’ai un forum pour photographes et je veux pouvoir activer un ChatGPT pour tout ce dont ils ont besoin dans l’univers de la photographie.
Possible ?
Oui, avec Chatbot, vous adaptez simplement l’invite système et il agira en personnage. Il est également extensible. Vous pouvez le personnaliser avec des outils supplémentaires (si nécessaire).
Génial, j’adorerais installer ce plugin mais je ne suis pas sûr d’en être capable / je ne suis pas développeur… mais j’aimerais le rendre disponible pour notre communauté
pouvez-vous m’aider ?
Ma communauté https://forum.fotografos.online
Êtes-vous auto-hébergé ?
Il y a des instructions sur le Sujet du plugin.
L’installation est très similaire à l’ajout de n’importe quel plugin :
Mais bien sûr, il existe des paramètres uniques.
Bien sûr, vous pouvez m’embaucher pour vous offrir un support plus dédié (n’hésitez pas à m’envoyer un message privé).
