לא יכולתי לערוך תגיות לנושאים ישנים
סיכום מבוסס בינה מלאכותית
cmdntd reported being unable to edit tags on old topics, even after disabling the multilingual plugin. JammyDodger suggested checking browser console and server logs for errors, and asked if other plugins (like Tickets) might be involved. cmdntd confirmed the issue persisted without multilingual enabled, and noted new topics could be tagged normally — suggesting a conflict with older topics. cmdntd listed three tag-related plugins: discourse-docs, discourse-multilingual, and discourse-solved, and asked if disabling (rather than removing) them would suffice. JammyDodger recommended rebuilding without the multilingual plugin to isolate the issue, referencing a prior report where activating it caused tag errors. cmdntd shared console logs showing deprecation notices and CSP warnings, but no direct errors related to tagging. Finally, cmdntd confirmed removing the multilingual plugin resolved the tagging issue — though they lamented losing its features. JammyDodger acknowledged the bittersweet nature of troubleshooting, and closed the topic to consolidate discussion in the main multilingual plugin thread, hoping the developer (@angus) could resolve it.
I have some topics have “no tag” before I use tags in forum
Now I could not edit to add tags for these old topics
Do you know this case?
Is this the same issue as the one you posted in Multilingual Plugin 🌐 - #55 by cmdntd? If so, including that you think it’s a plugin creating the errors is worth mentioning. :+1:
Could you check your console for errors when you try and tag one of these problem topics? Or is there anything in your /admin/logs that could provide a hint as to what’s happening?
No, these issues are different.
This issue still occurs when I turn mutilingual off.
In some cases you may need to remove the plugin from your app.yml to be sure, however the errors in your logs may indicate if there’s a problem one way or the other. Could you check those and see if they contain any useful information?
There has been a similar issue with the Tickets plugin if you also have that installed?
I do not see anything make this error.
But when I try to create new post with the same title and content, I could set tags for the new one.
I think there is a conflict with old topics, before I set tags in forum.
There are 3 plugins I used related to tags:
  1. discourse-docs
  2. discourse-multilingual
  3. discourse-solved
Could I disable it, in stead of remove it from app.yml?
Based on this:
I would suggest rebuilding without the plugin in your app.yml and seeing if that resolves your tag issues. If so, it would help narrow down what is happening.
(Though a copy of the error would also help)
About log:
I do not see any errors related to this issue at console and admin log
Console
vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:4775 [THEME 5 'Discourse Kanban'] Deprecation notice: route:discovery.parentCategory was replaced with route:discovery.category (deprecated since Discourse 2.6.0)
e.default @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:4775
vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:4775 [THEME 5 'Discourse Kanban'] Deprecation notice: route:discovery.categoryWithID was replaced with route:discovery.category (deprecated since Discourse 2.6.0)
gtm.js?id=GTM-PMQ7HQM:323 Refused to execute inline script because it violates the following Content Security Policy directive: "script-src https://help.working24.net/logs/ https://help.working24.net/sidekiq/ https://help.working24.net/mini-profiler-resources/ https://help.working24.net/assets/ https://help.working24.net/brotli_asset/ https://help.working24.net/extra-locales/ https://help.working24.net/highlight-js/ https://help.working24.net/javascripts/ https://help.working24.net/plugins/ https://help.working24.net/theme-javascripts/ https://help.working24.net/svg-sprite/ https://www.googletagmanager.com/gtm.js 'nonce-3effa17d995f0c4a591397e3c0f05e82' https://help.working24.net/logs/ https://help.working24.net/sidekiq/ https://help.working24.net/mini-profiler-resources/ https://help.working24.net/assets/ https://help.working24.net/brotli_asset/ https://help.working24.net/extra-locales/ https://help.working24.net/highlight-js/ https://help.working24.net/javascripts/ https://help.working24.net/plugins/ https://help.working24.net/theme-javascripts/ https://help.working24.net/svg-sprite/ https://www.googletagmanager.com/gtm.js https://gc.kis.v2.scr.kaspersky-labs.com wss://gc.kis.v2.scr.kaspersky-labs.com https://connect.facebook.net/vi_VN/ https://viewer.diagrams.net/". Either the 'unsafe-inline' keyword, a hash ('sha256-B6lPd158nbG8rCxsx2kpy/8ua86KST6EpT4plGVsNqY='), or a nonce ('nonce-...') is required to enable inline execution.
(anonymous) @ gtm.js?id=GTM-PMQ7HQM:323
DevTools failed to load source map: Could not load content for https://help.working24.net/service-worker-830f2ab5c474b7eaaae38cdcf94dca4de37979dd39ec651a6084a3c2e3dab0e0.js.map.js: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/chunk.920.745f5f3701905e2ba440-514a58226f43a671cda187c9c828ae5c762c085ff19b63dbe87db4e65fc66eab.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/vendor-f0c781f730e82c88943734cef010b6e9c9dd480b26418aa9e8aac96e21414e14.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/chunk.143.0e5561a71d4559ae4302-0ef3b40d0877f0b3cbde86e57af048e6793444b622317128c03f76f9a97262de.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/discourse-2bfa9b1f6408b9c4dc8896664b0d43b8f20f6284f0e6f9d378f8db2b03c73b13.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/admin-a46876b7fd27e136549e8756dc3df150a4257e92880ec738b2e1e40a8819dbf6.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/assets/start-discourse-91e64639509fc02c56f1839e3a294f1a0ae116f3b22b083143d871b2c58f1cfd.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://help.working24.net/theme-javascripts/cropro.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
includes.js?v=35a79b300ab5afa978cb59af0b05e059:839          POST https://help.working24.net/message-bus/9bfe02450f4e45a798f92b9e0da66c36/poll?dlp=t net::ERR_CONNECTION_TIMED_OUT
XMLHttpRequest.send @ includes.js?v=35a79b300ab5afa978cb59af0b05e059:839
send @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:562
ajax @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:538
o @ discourse-2cd98fe52221de287910a27f0a156f8bd21e34a5c0f4fcbfaea9cfcb1f0086ab.js:3568
r.baseUrl.r.ajax @ discourse-2cd98fe52221de287910a27f0a156f8bd21e34a5c0f4fcbfaea9cfcb1f0086ab.js:3570
k @ chunk.920.745f5f3701905e2ba440-570990cd1fd15d3fa7f426dfd7706e4a000e11a6bfa994dc8c1ba387ed2d47b0.js:1600
r @ chunk.920.745f5f3701905e2ba440-570990cd1fd15d3fa7f426dfd7706e4a000e11a6bfa994dc8c1ba387ed2d47b0.js:1609
(anonymous) @ chunk.920.745f5f3701905e2ba440-570990cd1fd15d3fa7f426dfd7706e4a000e11a6bfa994dc8c1ba387ed2d47b0.js:1604
setTimeout (async)
complete @ chunk.920.745f5f3701905e2ba440-570990cd1fd15d3fa7f426dfd7706e4a000e11a6bfa994dc8c1ba387ed2d47b0.js:1604
e.complete @ discourse-2cd98fe52221de287910a27f0a156f8bd21e34a5c0f4fcbfaea9cfcb1f0086ab.js:3567
l @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:267
fireWith @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:268
O @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:550
(anonymous) @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:561
load (async)
send @ vendor-f5869d031b4b9ed1cf112ac4f683736826617a0cf208a3c0b593a0bddeba3cca.js:561
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
error (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
includes.js?v=35a79b300ab5afa978cb59af0b05e059:839          POST https://help.working24.net/message-bus/9bfe02450f4e45a798f92b9e0da66c36/poll?dlp=t net::ERR_NETWORK_CHANGED
setTimeout (async)
error (async)
setTimeout (async)
error (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
setTimeout (async)
load (async)
includes.js?v=35a79b300ab5afa978cb59af0b05e059:839          POST https://help.working24.net/message-bus/9bfe02450f4e45a798f92b9e0da66c36/poll?dlp=t net::ERR_INTERNET_DISCONNECTED
Admin logs (error logs with other times, nothing related with this issue)
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-ASN.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-ASN.mmdb
29 Apr 8:11 am
10
(google_oauth2) Authentication failure! csrf_detected: OmniAuth::Strategies::OAuth2::CallbackError, csrf_detected | CSRF detected
29 Apr 1:09 pm
54
#<Net::ReadTimeout: Net::ReadTimeout>
Tu 10:28 am
407
Tu 10:34 am
43
Deprecation notice: `target_usernames` is deprecated, use `target_recipients` instead. (removal in Discourse 2.9.0) At /var/www/discourse/app/controllers/posts_controller.rb:178:in `create`
Tu 11:49 am
We 10:24 pm
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-City.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-City.mmdb
9:44 am
9:44 am
Deprecation notice: `target_usernames` is deprecated, use `target_recipients` instead. (removal in Discourse 2.9.0) At /var/www/discourse/app/controllers/posts_controller.rb:181:in `create`
6:53 pm
11
7:07 pm
6
NoMethodError (undefined method `name' for #<Array:0x00007fee0f3d8cb8>) app/controllers/tags_controller.rb:249:in `search' app/controllers/application_controller.rb:404:in `block in with_resolved_loca
8:07 pm
You’re right!
It’s ok now when I tried to remove mutilingual plugin.
It’s pity to not able to use this plugin, because its features are important.
Fault-finding can be a bitter-sweet process. :slightly_smiling_face: It’s good you’ve narrowed it down though, and hopefully @angus can take a look and get it up and running again.:crossed_fingers:
I’ll close this topic off in favour of the main Multilingual Plugin 🌐 - #55 by cmdntd one to better keep track of the issue. :+1:
