我在自己的帖子中看不到点赞按钮
for what reason can this happen?
If you are the author of a post, you will only see the like button if your post has received a like.
If that’s not what’s going on here, there are a couple things to check on:
  • Ensure that “like” is listed in the post_menu site setting
    /admin/site_settings/category/all_results?filter=post_menu
  • Try accessing your site in safe mode to make sure a theme or plugin is not hiding it
    /safe-mode
7 个赞
Yes, it was this) Thank you! I somehow did not think about this option)
4 个赞
This topic was automatically closed after 15 hours. New replies are no longer allowed.
