יש לי שאלה לגבי הגדרת מערכת הדואר
Hello! I come from China, the following is from translation software
This is my first time to use the international forum. If there is a low-level error, please help me correct it
Thanks!
I am using /var/discourse/discover-setup to configure “discourse”,
But I have a big problem with email.
I tried to move the mailbox configuration of other forum software,
when I try to send mail,
Then I found that the mail was sent to this strange address.
And I was very upset that I didn’t receive the email correctly.
Here is my Foxmail software configuration, which can work normally:
(I cant upload image and https address :frowning: )
I have tried a variety of configuration methods, please help me point out my configuration where there is a problem!
I can try my best to add the missing information in the post.
If you can help me solve this problem, I will be very grateful!
FoxMail: Foxmail for Windows
Add: I use Alibaba enterprise email
AliMail Enterprise Edition (aliyun.com)
If you need to test, I can provide you with an account number
UUID@hibot.top is not the email address used, it is the Message ID for the particular email that was sent.
When you try to send a message, does any error show up on the logs? – https://forum.hibot.top/logs/
(sorry im late
i clear the log and send again and the log have nothing in it (sry for my broken english
Thats Log in SideKiq
im still in trouble
please help me thanks!
i reinstall it and try to send verify email,thats the logs:
Could your firewall block port 465 ?
telnet smtp.hibot.top 465
I connected for 10 sec and it disconnected
@Benjamin_D
And thanks for your reply (When you reply, the time here is 1pm and im sleeping
You can run the discourse-doctor directly in discourse folder, and the MAIL TEST section of test result may help a lot.
I recommend to using the DirectMail(邮件推送) which also Alibaba product with some free quota, it just like Mailgun.
i tried,but the error is same:end of file reached
@Hawm
I use Business AliMail because its free :smiley: ,but i will try directmail ,thanku
It could be the port 465 issue.
Ok,I am checking this post
And DirectMail its 2 expensive for me i cant send 50K mail in 6month,and it cost me 11USD
My Server only 3.5USD/month :joy:
You ignore the last section.
And if you want to keep using the Busisses Email you can try if it can support other port.
oh im blind(but DirectMail running in 465 too
thank for you replying ,Thats Helpful to me
I think port 465 problem should add in this post: Troubleshooting email on a new Discourse install - howto / sysadmin - Discourse Meta
You can using port 80 if you don’t really need SSL/TLS, it’s working to me.
ok i will try thank u
Just added some more words saying that 465 is usually wrong :slight_smile:
wow,thank for u help😀
