I Have an Issue With Swap File (2GB) During Installation
Hello,
I am currently having issues with the last step of discourse installation. I got this reply from my from ssh client while trying to enter " ./discourse-setup"
Please what should I do?
From the output you provided it would appear that you have a 1 GB swap file, not a 2 GB one as required by Discourse. I’d suggest disabling the existing swap file by running
swapoff /swapfile
then running
./discourse-setup
again so it can create the 2 GB file. Did you previously set up a 1 GB swap file?
4 إعجابات
Yes I did set up a 1GB swap file because it was part of the instructions in vultr instruction documentation
إعجاب واحد (1)
This? https://www.vultr.com/docs/how-to-install-discourse-on-ubuntu-14-04 Those docs are pretty outdated: Modified on: Thu, Feb 26, 2015 at 12:32 pm EST
The up-to-date instructions are here:
discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
3 إعجابات
I have turned off swap file but am still getting an “insufficient swap space” message.
إعجاب واحد (1)
I suggest resetting your VPS with a clean Ubuntu Server 16.04 install and starting over from scratch.
3 إعجابات
Ok I will try that now. Thanks
إعجاب واحد (1)
[quote=“codinghorror, post:6, topic:57028, full:true”]
[/quote]I have done what you said but am still having problem with the swap space stuff. Please what do I do?
The easiest thing would be to use digital ocean.
You could try to create a 2gb swap file yourself. If you do that and are still having trouble, include the output from
free -h
إعجابَين (2)
