Icons in der Symbolleiste des „Verfassen"-Bereichs
I’m modifying the icons on the compose pane toolbar. The default icons are shown below: -
I’m displaying an extra book icon as I guessed the name of the icon. Is there a list of the built-in available icons?
Yes, we use font awesome. All of these icons should be available: Font Awesome Cheatsheet
Thanks Kris.
That’s what I thought at first, but when I specify a FA icon name from that page it doesn’t display eg: “fa-paw” appears as a blank space, as did the other FA icon names I tried. Whereas if I choose “book” it works.
This is the context of it’s usage, in case that helps:
  api.onToolbarCreate(toolbar => {
  toolbar.addButton({
    group: "extras",
    icon: "book",
    title: "Title_Name",
    perform: e => e.addText("Test to add to compose textbox.")
What font awesome version are you expecting?
I’m not specifically after Font Awesome. I’m just wanting a list of supported icons so I can choose suitable ones.
“Book” works - and I presume this isn’t font awesome, so presumably there’s some specific unicode icons supported? Or, perhaps there’s a special way to list the FA icon name in my code above that I’m not doing.
No, ‘book’ works because behind the scenes it is being changed to ‘fa-book’, for ‘paw’ to work, you would have to use ‘paw’.
Perfect @cpradio, “Paw” worked correctly.
So now I can reference the FA icon list that Kris provided above.
Thanks all. I’m sorted.
