Idea: mark as read per new topic from list
In a feature discussion titled ‘Idea: mark as read per new topic from list,’ SidV proposes a way to mark individual topics as read directly from the ‘new’ topic list (e.g., https://meta.discourse.org/new) without opening them — similar to marking emails as read in a list view. He notes that existing features like ‘dismiss new’ (codinghorror, codinghorror) mark all new topics as read at once, which isn’t ideal when only some are desired to be marked. sam suggests using the hidden ‘bookmark’ feature with keyboard shortcuts j b to navigate and mark topics, though this doesn’t directly mark topics as read. SidV appreciates the shortcuts but suggests adding an ‘M’ key shortcut to mark a topic as read directly from the list — a feature he believes would be great for efficiency. The core idea is enhancing the topic list with per-item ‘mark as read’ functionality, ideally via keyboard, to improve user workflow without forcing topic entry.
Well, I’ve already read “ability to mark as read” thread, but it does not fill with my idea.
When you visit the “new” section from your forum (example: https://meta.discourse.org/new) you have got a list of topic that you do not read. Thats ok, but, how do you mark a topic like read without clicking on it?
I don’t want to ignore, or mark as read all the list
Think about this feature such as feedly list of “feeds” (or topics).
In feedly, you can press “m” from the keyboard and the system mark the line as read, so the user could reduce the number of unread’s topics.
I hope you can understand my idea.
Regards!
2 Me gusta
Use the “dismiss new” button. This will only appear if there are more than (n) new topics, however.
But, that button will make as read all the new topics.
Not just one. :frowning:
Yes, the idea is that you read the ones you want to read, leave the ones you do not want to read, then push “dismiss unread”
We have the “bookmark” hidden feature I use quite a lot.
j b in topic lists, we could extend that to support “dismiss” not against it, but its a super advanced user feature.
4 Me gusta
@sam thats is great.
Love the “J” and “B” keyboard shortcuts to “move” between messages or post (or topics in a list).
I think It would be great if discouse add the “M” key shortcut to “read or unread” in the line.
