If I try to change ownership of a topic but nothing
as an admin when I click Change Ownership nothing happen
I have start this path primarly because I wanted to “transform” a post (a comment in a topic) from another user to a topic
Than would be ideal if can do directly
As I read that maybe is not possible I cpied the message and created a topic manually , but now I cannot change ownership…
yes this was reported already, along with many other post admin functions for nested topics. i’d advise to be patient.
https://meta.discourse.org/n/nested-mode-disables-post-admin-wrench-menu-actions/403155?sort=top
if you go to flat mode you can probably do it.
It worked. You are the best!
