Wenn ich eine „rebuild app" durchführe und die PuTTY-Sitzung schließe, wird der Prozess unterbrochen?
I started ./launcher rebuild app to update docker using Putty to the remote server, and during the process I needed to restart my local computer, then I rebooted but the new Putty session is now clean and I don’t know if the rebuild process still going on, currently I can’t reach my forum, but because it takes time to complete the rebuild, I don’t know if have to wait or the process failed.
Help…
So, it appears that the process gets interrupted if you close a Putty session.
I run the commands again, and now the forum is up an running again.
For newbies, rule of thumb, don’t close Putty session during rebuild.
Thanks,
The solution is to use tmux before you start. If you are disconnected you can reconnect with
 tmux attach
When you log in again. (screen is similar).
