Try click out to done your current edit tool, before save your image.
It seems depends on paragraph/image below current image. If content next to image is null (or heading), it will not able to complete action or replace next image.
This TC is brilliant - but I’ve noticed an error in the browser console which seems to be associated with it:
It still seems to work though so this is no big deal.
Also, I do wonder if it would be better if the options to crop and edit tied in better with the new ‘edit the title’ functionality, perhaps with an icon or two next to those ones instead. It is a bit of a clash when hovering gives one lot of options and clicking another!
Editing works, but it didn’t save and I got this CSP related error:
Message
CSP Violation: 'eval'
(a=0)=>{let b;const c=class{};}
Backtrace
/var/www/discourse/app/controllers/csp_reports_controller.rb:14:in `create'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/actionpack-7.0.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/actionpack-7.0.3/lib/abstract_controller/base.rb:215:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/actionpack-7.0.3/lib/action_controller/metal/rendering.rb:53:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/actionpack-7.0.3/lib/abstract_controller/callbacks.rb:234:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-7.0.3/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:415:in `block in with_resolved_locale'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/i18n-1.10.0/lib/i18n.rb:328:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:415:in `with_resolved_locale'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-7.0.3/lib/active_support/callbacks.rb:127:in `block in run_callbacks'
I tried iPad and iPhone, and I’m using S3 — if any of those plays some roll.
CSP situation is resolvable with the new patterns used in:
Would love to see a PR that adds this in.
Hello, very useful component. Is it possible to add a circular crop to an image?
This is an extremely great component for any community!
Atm this will come in handy to create forum tutorials on how to functions!
Thank you so much for this truly wicked & wild feature rich idea!
Have you tried it using a mobile?
yes it works to some degree on testing.
That’s nice. Maybe I have to give a new try to it. Because last summer it did not work on any Apple’s products or androids either.
Cropping and some things work well. I did find drawing with pen might not…
I am on android. I clucked in oreview window to cluck on image.
Seems like it compresses the image after using the plugin. Or messes whit the quality somehow.
It also removes the lightbox from the image that have been edited, I guess that’s problem. It won’t load the full image when not in lightbox.
So you are telling that major parts of an annotation tool actually isn’t working
Quite possibly. at keast with drawing.
The crop add text make squares? seems to work though. as mentioned very quick test.
Simple enough to introduce feature in an announcement detailing mobile has limitations and for best xp use a desktop pc.
If your on mobile this could be a limitation due to image size.
It removes the lightbox function after using the edit.
Possible because of mobile use as well.
good to know definitely need more testing and if need be state desktop only with keeping mobe availability quiet from non staff. Perhaps.
Thank you for providing test feedback.
I gave a short and fast testdrive. It changes scale of an image wrongly, at editing window anyway, but I could do all annotations I wanted — I didn’t try cropping. But… it saved only my edits and image itself was lost.
So, I still count this one as a broken component.
Sure, perhaps that image was too big and perhaps CDN via S3 was the issue, but anyway — if those limitations are true then this is… too limited.
But let’s be straight. This is same like basic audio and video recording. Only limited desktops need such tools because all mobiles can do everything natively.
So perhaps this should tag as #desktop-only
Very good possibility. I haven’t tested this on a desktop yet. I presume it works well as intended?
Not me either. I’m using desktop so rarely nowadays because only job I need it for is audio editing. I have to try it at some point quite soon.
