Hi there,
Does the Slack integration allow images to move with posts? We are currently researching the possibility of using Discourse as our ‘long term memory” and have many images included in our Slack posts. The text will not mean much without the images
. Thank you in advance
7 curtidas
Is this possible @david?
6 curtidas
Hi @david,
Could you help me with my question regarding the ability to use the Slack integration to transfer images with posts to Discourse?
Thank you ![]()
Hi @WendySmall - sorry for the delay in responding here! Unfortunately the current “transcript posting” does not support importing images from slack to Discourse. It’s something we might look at in future, and would certainly be pr-welcome if anyone would like to give it a try.
5 curtidas
Obrigado, David. Peço desculpas também pela resposta tardia!
1 curtida
