@gerhard : Could I acheive the sanitizing of bad characters encoding after the migration by using the Sidekiq ? I am really new to Discourse to I may not understand of it works.
Or maybe a SQL script directly into the MariaDB ?
Thanks a lot !
Thanks a lot !
Sure! You could also just edit each post by hand. Itās on the order of 10X easier to do it before hand when itās possible to just start over again.
I tried a bunch of stuff to try to fix up the encoding on the mariadb side, but didnāt come up with a solution. Hereās some code that I used to fix up the encoding on an import that Iām working on.
### WIN1252 encoding
win_encoded = ''
begin
win_encoded = raw.force_encoding('utf-8').encode("Windows-1252",
invalid: :replace, undef: :replace, replace: ""
).force_encoding('utf-8').scrub
rescue => e
puts "\n#{'-'*50}\nWin1252 failed for \n\n#{raw}\n\n"
win_encoded = ''
nice thanks
It was a painful experience. I tried multiple encodings and included multiple ones in the post so that I could compare them. This one seemed to solve most problems most of the time. It took me much longer than Iād have liked to figure out .scrub
, as without it Iād end up with strings that could no longer be parsed with gsub
Does anyone yet have a good solution to import nested lists from phpBB?
Iām not enough of a ruby guy to know how to approach it ā sitting over this
def process_lists(text)
# convert list tags to ul and list=1 tags to ol
# list=a is not supported, so handle it like list=1
# list=9 and list=x have the same result as list=1 and list=a
text.gsub!(/\[list\](.*?)\[\/list:u\]/mi) do
$1.gsub(/\[\*\](.*?)\[\/\*(:m)?\]\n*/mi) { "* #{$1}\n" }
text.gsub!(/\[list=.*?\](.*?)\[\/list:o\]/mi) do
$1.gsub(/\[\*\](.*?)\[\/\*(:m)?\]\n*/mi) { "1. #{$1}\n" }
Does anyone have an idea how āloopingā over a nested list could look like?
Hereās a bbcode example
[list]
[list=a]
[*]a
[*]b
[*]c
[*]d
[*]e
[/list]
[*]outer list
[/list]
I have not but I will, thanks. Though I try to avoid using it as I donāt want to support additional BBTags on the long run - I really would prefer to convert the stuff on import. The nested lists arenāt a deal breaker but would be great to have them.
You could create a backup, upgrade to phpBB 3.2 and use my experimental branch. It has a much better support for BBCodes.
That sounds interesting but Iād rather not want to fiddle with phpBB anymore. Apart from the lists the import process is more or less streamlined already. That would kind of set us back into more work and testing. But good to see the 3.2 progress coming along nicely.
Hey @helmi
Yes, we have been wrangling with these kinds of issues for a month now, migrating a legacy vB3 forum with nearly two decades of all kinds of crazy uses of bbcode, nesting, embedding, etc.
It is non-trivial to get this kind of migration up to 99.9% perfect. For example, we wrote Ruby code to strip all bbcode tags from our code tags because markdown does not ālikeā bbcode inside fenced code blocks.
On our end, we are still finalizing a lot of Ruby preprocessing routines and we are getting closer and closer but we will never get to āperfectionā or ā100%ā with nearly two decades of posts by some very creative bbcode users (not to mention all those users who cut and pasted into posts, etcā¦)
We are still working on cleaning up issues related from BBCODE to MD.
Sometimes I think ājust strip it all awayā ā¦ LOL
Looks like weāre still facing some issues with Usernames getting modified or not imported at all when containing some special characters.
Are there any known issues with the importer or am I getting the unicode username option in discourse wrong? I enabled it but the whitelist still contains umlauts. Do I need to delete the whitelist to allow all unicode characters or do I need to list all characters? My thought was enabling unicode allows all unicode and disabling it only allows the whitelisted ones.
When importing it looks like some characters like @ or * are replaced by _ ā i can imagine where @ could cause problems with @mentioning butā¦ I just wanted to make sure before we manually deal with all those users before importing (which would be a big hazzle).
Any hints on that?
Cheers,
Frank
Even when you enable Unicode support, it still only allows letters and numbers. See Unicode usernames and group names
Hello,
First of all, thank you for all the documentation and the help of this topic.
Iāve just import an old phpBB3 forum into a brand new Discourse one.
Everything ran quite smoothly with the 200k posts and 20k attachments, but sidekiq had a little trouble digesting everything after importing.
Iām now facing a new issue with image tags which were included in a url tags, like that :
[url=http://www.casimages.com][img]http://nsm01.casimages.com/img/2009/04/24//090424092900546293539010.jpg[/img][/url]
After importing (converting bbcode to markdown), these images are just looking like links :
[nsm01.casimages.com/img/2009/04/24//090424092900546293539010.jpg](http://www.casimages.com)
Is there a way to process/rebake these links so that they are displayed as an image and can be automatically uploaded to the s3?
Thanks in advance for your help
Search system settings for ādownload remoteā
EDIT: Oops. Looks like that wasnāt your problem. Sorry.
Thank you Jay. Yes, I already enabled the ādownload remoteā setting. My problem is that these images are displayed as link (and the image url is only āthe displayed partā of the link, the target does not match an image content).
Hi,
I currently have a forum imported from phpbb.
Iām thinking about importing another phpbb forum (36000 messages, 230 members) inside my existing Discourse installation. They share common categories and users.
Users account could be manually merged.
As for the messages, after the import they would be manually moved into existing categories.
Would that work kind of like out the box from the import script or would it be mayhem?
What happens if I import a phpbb forum and some user emails already exist in my current Discourse?
Youāll need to wipe the import_id
custom fields, or the new posts will be considered to already have been imported.
This sounds like something you should expect a lot of mucking around in a local install for, using a backup of your main database.
Thank you for this valuable information that I didnāt think about
Yeah, Iāll do that and try on a test server to see if it can be managed.
About the context:
I host a national Discourse forum about unicycling.
I also host a phpbb forum for a local unicycle association.
Both forum share some of the same users, and some topics or discussion subjects are redundant. The idea would be to merge the local association forum into the national forum so there are no more topics redundancy, and create a group/gategory for the local association related topics.
Plus, people who are only on the local association forum will join the national forum this way and maybe bring more activity.
Does anyone have an idea what the reason may be for Mysql not running in the import container?
Iāve done quite a few runs and that always worked but now getting
Can't connect to local MySQL server through topic:30810
Once I try starting the import. Tripble checked everything, rebuild the import container several times. Everything is there but mysql doesnāt seem to be running.
Iām a bit horrified as this is actually our real move to discourse today.
That looks strange. Whereās that coming from?
