אי אפשר לשנות הגדרות Persona כאשר ה-locale ברירת המחדל אינו אנגלית
Somehow it is not possible to change for example the allowed groups setting when the default locale is not English.
Locale set to German:
The error message is:
cannot_edit_system_persona: “System personas can only be renamed, you may not edit commands or system prompt, instead disable and make a copy”
Same steps with default locale set to English
2 לייקים
How were you able to edit the name and description, we do not make them editable, you need to rework prompts in other languages, so allowing you to simply rename is not ideal.
For now the way of working around it:
  1. Disable the default english person
  2. Create a new persona - copy and translate system prompt, ensure all commands are selected
And you will have an excellently working German persona.
EDIT… oh … I see the bug … tricky, will add a bypass.
לייק 1
Will be fixed per:
https://github.com/discourse/discourse-ai/pull/504
3 לייקים
This topic was automatically closed after 23 hours. New replies are no longer allowed.
