Continuing the discussion from Primary group not made primary:
I suggest that if a user receives a primary group with a default title that the user’s title get updated unless the title has been set manually.
Current behavior is that a new primary group overrides the title of another primary group, but it does not override the title of another regular group. This creates the bizarre situation where if you want a truly primary group with regard to title, you need to make sure to not set it as a primary group. It also means that the behavior is opposite of the way flair works with primary groups.
Surely if it overrides primary groups it should override regular groups?
