Here is the bug I have.
I write
It is displayed as
It is not a font bug because the character is in the HTML:
Here is a link to the post if needed: Création d'une application mobile.. quelle plateforme, quel environnement, les questions qu'il faut se poser - Mobile - Human Coders Forum
This bug was fixed last week, if you update this should be solved.
Hi.
Since the last Discourse update, when I write a post title that contains a quote ', it is converted to › preceded by a single space when I create the post.
[image]
If I click on the edit title button, the input correctly shows ' but it is always converted to › (preceded by a single space) when I do confirm the title edition.
[image]
Also it appears that if I write a double quote ", it will be converted to ».
Oni
24 juli 2019 om 16:16
3
I just updated mine and it doesn’t seem to be solved
UPDATE: It is solved but you need to edit the posts in order to make it visible. Do we need to rebake all posts ?
Canapin
(Coin-coin le Canapin)
24 juli 2019 om 16:23
4
Hi,
My Discourse installation tells me that it is up to date, but the issue is still here.
Oni
24 juli 2019 om 16:25
5
You need to update from command line
zogstrip
(Régis HANOL)
24 juli 2019 om 16:39
6
Yes, you need to rebake all the affected topics.
pfaffman
(Jay Pfaffman)
24 juli 2019 om 20:57
7
Yes, you need to rebake. If you have over 10K or 100K posts it might be worth trying to rebake only the necessary ones, otherwise, it’s easiest to just rebake them all.
Enter <yoursite>/admin/upgrade as the url.
Canapin
25 juli 2019 om 13:12
8
That worked perfectly, thanks.
