Including new categories in sidebar?
Hi guys.
I’d presume this must be trivial - yet I must ask as a novice who failed to find info on this - when a new category show up in left-pane?
I did not expect it not to show up and I’m guessing it is some ‘setting’ I’m missing with which new categories will get to left-pane right away?
If yes so then I’d curious - what’s the rationale behind such “defaults”?
Hello,
I assume that you are referring to the sidebar?
If you create a new category and it does not show up in the sidebar you have to click the :pencil2: icon and add them from there:
Okey, from how it behaves I think it’s per-user config/setting?
I might have started vaguely enough - I’m looking for site-wide config/tweak, so an admin setting?
Ok, found it in: Admin → Settings → default sidebar categories
