Install Discourse for development using Docker
There is no way to docker Discourse on a Mac with a M1 chip currently right?
When running d/boot_dev --init, I was running into this error:
ActiveRecord::NoDatabaseError: We could not find your database: discourse_development. Available database configurations can be found in config/database.yml. (ActiveRecord::NoDatabaseError)
I’m not sure if this is a bug in the boot_dev script, or if the discourse_development database is supposed to be created somewhere else. Either way, I was able to fix it with this change:
diff --git a/bin/docker/boot_dev b/bin/docker/boot_dev
index 89fdcf6f65..0e9c5ce7d5 100755
--- a/bin/docker/boot_dev
+++ b/bin/docker/boot_dev
@@ -122,6 +122,7 @@ echo "pnpm install..."
 if [ "${initialize}" = "initialize" ]; then
     echo "Migrating database..."
+    "${SCRIPTPATH}/rake" db:create
     "${SCRIPTPATH}/rake" db:migrate
     RAILS_ENV=test "${SCRIPTPATH}/rake" db:migrate
After that, the setup process ran properly, following the instructions in the OP.
I’m not familiar enough with the Discourse codebase to know whether this is the correct fix, but I’m happy to submit a PR if that would help. :slightly_smiling_face:
Oh yes please create a PR and link it here. Thanks!
Done!
Any luck with getting it to run?
I got this same error. I ran docker rm -f /discourse_dev and re-ran d/boot_dev --init and it worked this time.
Heads up:
I’ve just noticed the folder is data/postgres instead of tmp/postgres, which is also why the ā€œreset databaseā€ command aims to delete the data folder :slight_smile:
I thought I’d give the docker dev install another look, but keep getting:
Caused by:
PG::ConnectionBad: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory (PG::ConnectionBad)
        Is the server running locally and accepting connections on that socket?
Yet I can confirm the service is up (and works when using my normal non-docker ā€œmanualā€ install of discourse)
~/discourse_docker/discourse$ sudo service postgresql status
ā— postgresql.service - PostgreSQL RDBMS
     Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
     Active: active (exited) since Mon 2025-03-10 17:26:13 GMT; 6min ago
    Process: 2052109 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
   Main PID: 2052109 (code=exited, status=0/SUCCESS)
Mar 10 17:26:13 black-knight systemd[1]: Starting PostgreSQL RDBMS...
Mar 10 17:26:13 black-knight systemd[1]: Finished PostgreSQL RDBMS.
Does Docker Dev have specific and different Postgres connectivity needs?
I found the default :debug log levels to be way too verbose - the SQL queries drown out important errors. config/environments/development.rb allows for the setting of the DISCOURSE_DEV_LOG_LEVEL, but I don’t know if this can be done through the d/rails script?
Anyway I just temporarily hard coded it in config/environments/development.rb to config.log_level = :info and that solved the problem for me. Might help others as well.
I’m trying to spin this up with the Data Explorer plugin because I’d like to poke at the DE automation.
I got the container to start.
Then stumbled through ā€œinstallingā€ the plugin by cloning the repo and symlinking it into the disourse/plugins directory (is that what I was supposed to do? The guide really could be a lot clearer on that point).
I enabled the plugin through the UI. But when I try to access it, I get an error.
All that shows up in the log is this:
Processing by DiscourseDataExplorer::QueryController#index as JSON
Completed 500 Internal Server Error in 62ms (ActiveRecord: 9.8ms (5 queries, 0 cached) | GC: 2.9ms)
What am I supposed to do with this? Where are the details?
Have you run the migrations?
I did not have very good luck with symlinking my plugins folder:
I ended up moving to a normal folder as a result (see my last comment in that thread).
I think there are some incompatibilities currently with Docker volumes, file watchers, and symlinks.
Thanks for the reply @Arkshine! What should have alerted me that this needed doing? I did check the tutorial on installing a plugin, but I guess the plugin the tutorial uses as an example doesn’t need migrations?
In the meantime, I don’t know if this gets me over the hump because I’ve run smack into needing to get my company’s proxy cert into the Docker container & I haven’t done much with Docker before :frowning:
What problem are you solving? A development install is generally intended to be accessible only to the localhost (i.e., your computer) where the install is running.
Or maybe you’re trying to debug something that requires a cert like an auth system?
When I tried to start my image back up yesterday, it wanted to download gems?
Installing gems...
Fetching source index from https://rubygems.org/
Retrying fetcher due to error (2/4): Bundler::Fetcher::CertificateFailureError Could not verify the SSL certificate for https://rubygems.org/.
There is a chance you are experiencing a man-in-the-middle attack, but most likely your system doesn't have the CA certificates needed for verification. For information about OpenSSL certificates, see https://railsapps.github.io/openssl-certificate-verify-failed.html.
Retrying fetcher due to error (3/4): Bundler::Fetcher::CertificateFailureError Could not verify the SSL certificate for https://rubygems.org/.
Retrying fetcher due to error (4/4): Bundler::Fetcher::CertificateFailureError Could not verify the SSL certificate for https://rubygems.org/.
HĆ©, dus… wat gebeurt er als je het wachtwoord van het admin-account vergeet? De hele ontwikkeling opnieuw installeren?
Er kunnen geen e-mails worden verzonden, dus resets zijn niet mogelijk.
You can use the console to set a new password or create a new admin account.
There’s a route to become any user.
  http://localhost:4200/session/any-username/become
good 2 know you can reset password in the CLI
do you know if the con was ever fixed? :x: Cons: Will be slightly slower than the native dev environment on Ubuntu, and much slower than a native install on MacOS. ?
Why is this the case if you hit all the specs?
