In a support thread titled “Install fail, please help,” Huang_Ivan shared logs showing a failed Discourse installation during asset precompilation, with the error FAILED TO BOOTSTRAP. Arkshine advised reviewing earlier logs for more clues. pfaffman asked about system RAM and swap, to which Huang_Ivan replied with free -h output showing 3.6Gi RAM and 1.0Gi swap, with 600Mi swap used. jahan_gagan recommended increasing swap to at least 2Gi, noting that the build process is memory-intensive, and suggested retrying the app rebuild after adjusting swap.
== 20190103160533 CreateReviewables: migrating ================================
– create_table(:reviewables)
→ 0Last failed login: Mon Feb 24 20:33:37 CST 2025 from 218.92.0.198 on ssh:notty
There were 2 failed login attempts since the last successful login.
Last login: Mon Feb 24 20:30:46 2025 from 127.0.0.1
[root@VM-0-11-opencloudos ~]#
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile:build' failed with return #<Process::Status: pid 881 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"build", "hook"=>"assets_precompile_build", "cmd"=>["su discourse -c 'bundle exec rake assets:precompile:build'"]}
30348f30e7ed7ca4cc5f7202e9358c63736d3e04fd8bb63d3d1cabf47d6b0dbc
[root@VM-0-11-opencloudos discourse]#
