install: cannot remove '/swapfile': Operation not permitted
fallocate: fallocate failed: Text file busy
mkswap: error: /swapfile is mounted; will not make swapspace
swapon: /swapfile: swapon failed: Device or resource busy
/swapfile swap swap auto 0 0
vm.swappiness = 10
Failed to create swap: are you root? Are you running on real hardware, or a fully virtualized server
I get such a problem during installation, how can I solve this problem? I don’t use vps, I use vds.
