Integrate an existing database to Discourse
The discussion centers on integrating an existing external database with Discourse to use Discourse as a frontend. what asks if it is possible to connect to another database with its own topics and posts for this purpose. thoka responds negatively, suggesting that the user should instead import their data into Discourse. Following this advice, what inquires about the feasibility of importing a very large dataset, specifically asking if 500 GB or more can be imported or if there is a size limit. Falco confirms that there is no size limit for imports.
Would it be possible to have a API for another database with its own topics, posts, search and integrate that into Discourse so I can use Discourse as a front end and that as an backend?
No.
Think about import your data.
Is it possible to import 500gb+? Or is there a size limit
No, there is no size limit.
