Internet Explorer 11 stopped working after 2.4.0 beta7 update
Hi,
We’re getting lots of complaints from users on IE 11 that the forums stopped working for them after our recent update from 2.4.0 beta6 to 2.4.0.beta7 [920f8c6d75].
The symptoms are that the home page loads, but if you click any Category name or icon, the little “ball”/circle chasing its tail just sits there and the category never loads.
Anyone else seen this?
Gunnar
3 Mi Piace
We will look at it but reminder that we are dropping IE11 support by June 2020.
5 Mi Piace
Duly noted, and I’ll inform our users. Thanks for looking into it!
Gunnar
I think this may be related to some of the Promise related changes @markvanlan has been working on.
3 Mi Piace
I’ve just pushed a couple commits that will fix this issue:
Once this builds you should be all fixed up! Sorry for the interruption.
11 Mi Piace
Yup, that did the trick. Thanks for your quick response!
Gunnar
3 Mi Piace
