Hello everyone,
We have a bug in all browsers regarding mentioning.
It gets stuck in an infinite loop and the tab freezes completely.
We are in version 2.3.3 of discourse, however this patch FIX: infinite loop when mentioning in IE11 · discourse/discourse@1e4f0ac · GitHub
seems to fix the problem.
Is there a way that you can backport the fix to older versions as well?
Thank you,
Bas
(Bas van Leeuwen (OOO until May 25))
April 30, 2020, 1:47pm
(Nicolas works with me)
To clarify: we’ve tested this on 2.3.8 without plugins as well as our 2.3.3 production env. and the issue is reproducible in Chrome and Safari, it actually crashes the tab in both.
A patch to 2.3.8 would be very nice for us, at the moment we don’t have the budget available to upgrade to 2.4.x (we’re running quite a bespoke plugin setup; so small things tend to break a bit when upgrading major versions).
justin
(Justin DiRose)
April 30, 2020, 2:03pm
3
I’m afraid there’s probably nothing we can do for you since it’s been fixed in core already in later versions.
Your best bet is to apply the individual commit directly but there’s no guarantee of it working consistently.
Discourse is ending support for Internet Explorer 11 (IE11) on June 1, 2020 so that’s something to keep in mind too.
Bas
April 30, 2020, 3:06pm
4
We’re not patching this for IE11, but for Chrome and Safari.
But we’ll try to apply the individual patch and try to run a frankenversion
sam
(Sam Saffron)
May 1, 2020, 2:05am
5
Yeah 2.3 backports are not on the cards, we only ever backport to the stable or beta branches. stable is at 2.4.
Bas
May 1, 2020, 7:03am
6
Ok, clear. Thanks anyway!
