So this is apparently a docker issue from what i am aware, but newer docker versions implemented better IPv6 support.
My issue is that, when i enabled IPv6 that all my users IP addresses are shown as the docker containers IP Address.
Is this something Discourse actually supports by now and i just miss configured something? Or does Discourse need to implement this eventually? From what i am aware modern Docker installations come with proper IPv6 support by now and you only need to give the container a IPv6 address in a IPv6 Network, for it to work.
Everything else works and when someone connects via an IPv4 the record is shown correctly. The server also only runs Discourse nothing else.
