האם אפשר להוסיף אייקון ליצירת נושא חדש בסרגל הניווט?
One of the main features in a community is to add a new topic, but having the button scroll with the rest of the content, doesn’t seem “right” to me. Also, if I’m in a category where I can’t create a new topic (for example here, in the Documentation section), then I have to click the “back to the forum” link, to then click New Topic.
Can I add an icon like this, which will make it always possible to create a new topic, regardless of where I am?
EDIT: It seems that it’s possible with this component? Is that the only way, or is there a workaround for those communities that are not self-hosted and where the monthly plan doesn’t allow themes and components?
Do you mean hosted? Self-hosted folks can install what they like!
Check your hosting product plan - it should make clear what you can install or not.
התנצלותי… שינית את זה כרגע.
זה עבור קהילות אירוח מנוהלות, לא עצמית.
Looks like you could install that Theme Component on the discourse.org standard plan?
כן, גם אני ראיתי את זה. פשוט תהיתי אם יש דרך לעקוף את זה, since אני אתחיל עם תוכנית נמוכה יותר? אני מתכנן להשתמש ב-Communiteq, אז אשלח להם אימייל גם כדי לשאול על זה. תודה!
Have you had a look at the component below?
They allow you to install theme components on all their plans
I haven’t. Thanks!
I just saw this one:
I didn’t know that. That’s great then! Thanks for the info.
