I want to add a battle for the net widget to my discourse site for the day, is there a plugin I can can use or can someone show me how to install the widget?
Here’s the script I want to install for the day:
<script src="https://widget.battleforthenet.com/widget.js" async></script>
You can just put that code into a “theme component”.
- Go to your forum admin panel,
- “customize”,
- “themes”,
- choose your theme,
- “edit CSS/HTML”,
</head>, - paste the code in
- save
That code will only show on the date. If you want to test it now, use this code instead
<script type="text/javascript">
var _bftn_options = {
* Always show the widget. Useful for testing.
always_show_widget: true // @type {Boolean}
</script>
Thanks! That’s what I was looking for. Works great.
