Is there a way to quote something that was said on a different Discourse instance?
The discussion revolves around the possibility of quoting content from a different Discourse instance. DoctorJones inquired about this feature, but sam stated that it is not currently supported.
almereyda suggested that achieving this functionality might be possible through initiatives like the W3C Social Web Working Group and the IndieWeb Movement, which aim to federate conversations across platforms. They also mentioned the importance of distributed conversation graphs and the potential for forking and re-merging content.
The conversation then shifted to the idea of supporting the IndieWeb’s Webmention protocol, which would allow Discourse to notify external sites of links pointing at them. codinghorror mentioned that the whitelist for oneboxing is publicly available, while riking noted that the proposed feature sounds similar to trackbacks, which are often spammed.
almereyda revisited the idea of trusted Discourse federations and multisites with distributed conversations, citing the IndieWeb’s vouch protocol as a potential solution.
Is there a way to quote something that was said on a different Discourse instance? I’m guessing no, but thought I’d ask.
I know I can manually quote it, but I’d like Discourse to add the link arrows and have the expand functionality that it present in non manual quotes.
I’ve tried searching but there’s a lot of noise when you search for anything involving quotes.
Discourse being an Open Source application itself and dedicated to Open Standards, it theoretically build on already existing interface specifications, that try to federate conversations accross platforms.
The two leading initiatives in this directions are the
As federation is not trivial, I know it from experiments with the Federated Wiki, initiatives like the above will help to find common consensus on how to model distributed conversation graphs. This will likely also include ideas coming from the Open Annotation working group that also works on Hypothes.is.
Further more, as I am interested in aesthetically designing these distributed/federated conversations, the same question has already been raised earlier and could even be used to some weird scenarios as merging two Discourse instances, now that I think of it.
The important part here is to get the content of one site to the other, with possibilities of Forking and Re-Merging, i.e. Pull Requests known from Git(Hub).
One of the noisy results when searching for quotes that I provided delivers another small piece of the puzzle. In the end, the user’s interface itself should facilitate the creation, visualization and maintenance of distributed conversations. This is a task not to be solved by Discourse alone, as mentionned earlier.
But it can help with that, as its name implies sociological reasoning about the underlying principles, regulated algorithmically by its codebase.
Just my € 0,02.
No there is no support for this but sounds like an interesting power user feature, possibly an extension of one boxing a post
Thanks for the reply Sam. I thought this would probably be the case, but thought I’d seen something like this being used before. I must have been getting confused with one boxing.
https://greedgamer.com/t/what-game-are-u-playing-now/29/5
Some Thing like this ?
That is the 5th post
… but on steroids, allows you to select the section quoted as well.
@sam, would you mind webmentionning the domains that Discourse oneboxes from? Maybe just a small, little addition with huge federation chances.
I don’t know what this means. The default whitelist is in the public open source code, visible to everyone.
To reformulate, my question was:
  • Can you as the Discourse maintainers imagine to support IndieWeb’s Webmention protocol to notify external sites (Loomio discussions? Blogs?) of links pointing at them.
The conversation graph, as currently shown by in- and outbound links to a topic, could then possibly traverse domains.
I’m taking inspiration here from what Discourse does already, plus GitHub’s style of adding references to a conversation.
That sounds very, very much like POST /trackback to me. Which, by the way, is something spammed to every single webserver in existence.
See also
With
in place, can we imagine trusted, in this case vouched, Discourse federations and/or multisites with distributed conversations takeing place?
http://twitter.com/brennannovak/status/481411357279911938
Btw., to the mods @codinghorror and @sam, I just wanted to revisit the
and don’t have access to said topic anymore. Do you know why?
