Is there a way to reduce the size of full screen chat?
סיכום מבוסס בינה מלאכותית
Jack_McCarthy asks if there’s a way to reduce the size of full-screen chat in the Horizon theme to prevent overlap with the sidebar, as the rounded corners become sharp and the scrollbar overlaps when the sidebar is adjusted with margins. tobiaseigen suggests avoiding customizing the Horizon theme, and chapoi confirms that Horizon is intentionally non-customizable to avoid endless modifications.
The sidebar on my site has these nice rounded corners but when chat is maximized, the right corners become sharp again. It’s hard to capture in screenshots but the scrollbar also overlaps with the chat box a little bit.
I’m using the Horizon theme.
I think this is because I added some margins to the sidebar so that it wasn’t hugging the edge of the screen so closely which moved it over to the right a little bit. Is there a way to slightly reduce the size of the full screen chat to avoid this conflict? I haven’t been able to find a solution by looking at the css myself.
Hi @Jack_McCarthy! Were you able to figure this out? I think you likely will want to avoid customizing the horizon theme anyway if you can avoid it since it’s officially maintained.
Hello @Jack_McCarthy
Yeah sorry, Horizon is meant as non-customisable, so can’t help you out. I know it seems like a small thing, but if we start we never end.
