こんにちは皆さん、
このプラグインをインストールしました:
しかし、私が求めているのは、ユーザーの取引を評価できる単一のプラグインです。そうすれば、将来的に他の人がそのユーザーが良心的な売り手なのか、そうでないのかを知ることができます。
このようなプラグインは存在しますか?
追伸:サポートカテゴリではないかもしれませんが、投稿できなかったので、ご了承ください。
こんにちは皆さん、
このプラグインをインストールしました:
このようなプラグインは存在しますか?
How do you envision this working? Can you provide some example UI or other websites that do this?
Yes, @mingogomes is my chief redactor. He didn’t know that I had opened a thread to ask the same thing.
Well, the first image is mine, my id of a forum called hard2mano. It’s a closed forum, you enter in 2 ways, invitation, and another way, but it’s not the time to explain it.
As you can see in my profile you can see the wall of fame and there are collecting data such as when was the sale/purchase if it was positive/negative, a brief description of the treatment given/received and a brief description of the article sold/bought.
All of this helps users know whether to trade with the user. Imagine a user who sends everything on pizzahut wrapping paper, they exist!
One of the open forums you could see or consult on this topic is [VENDO] Placa Asus Maximus VIII hero Within its buy/sell section you will find a very similar style. Your own hall of fame, etc…
We would like something similar
This is also managed in SMF with Karma points. This would be a nice to have as an add-on, the possibility to rate users and every admin can choose what does that rating means.
Maybe a useful user with relevant answers, or maybe a trustable user in a marketplace.
Having the choice to only have the rating plugin active by category, theme author, things like that. The issue would be to do the plugin flexible enough for multiple uses/meanings without making it too complex.
Just an idea … but you could solve this also with Discourse badges. For example … after sale you show purchaser possibility to give thumbs up-down but you assign a custom badge to user.
As I said … just an idea.
P.S.
Trading Buttons plugin doesn’t identify buyer when topic is marked as sold … there’s no “transaction” as such. This plugin is simple for a reason … full sell-purchase/purchase-sell system would be very very complex
Here’s a thought on the subject. There are a lot of ways user ratings could be used on a forum, largely dependent on the type of forum.
Could this overlap with a general rating system for a user’s topics and responses? With there being different forum styles, such as a Q&A, discussion, and buyer/seller ratings, would it be possible to have all of these in one plugin rather than 3+, or would it be necessary to have different ratings, one for one’s trustworthiness in the market, one for the quality of someone’s questions and answers (like Stack Overflow), and one for the quality of one’s discussions?
The need to leave reviews in a marketplace setting is obviously one place that would be divergent, but couldn’t that be handled by a plugin setting to allow user feedback on why they gave a rating in the first place?
Is there any overlap with the following plugin?
実は、これは非常に便利なプラグインで、評価履歴の基盤となり得ます。しかし、平均的な販売・購入評価の要約を公開する機能や、誰に販売したかなどの具体的なデータを含む履歴へのアクセスも必要です。
トピックプラグインでは、トピック自体を評価することはできても、履歴は生成されません。![]()
こんにちは、@Franksssss さん。私もそのようなプラグインを探しています。見つけましたか?
まだです。実は、私たちにとっても有用ですが、それが可能かどうか、またその費用がいくらになるのかを誰も教えてくれませんでした。
開発者にTrader Feedbackプラグインの提供を依頼することは可能ですか?
お答えできません。理論的にはそれだけのためではありません。非常に明示的になります。開発者を雇うこともできます。
こんにちは、皆さん。
このようなプラグインにも興味があります。@Franksssss が提案されているように、ユーザー名の近くにユーザーを評価するコンポーネントがあるといいですね。また、評価されたユーザーのランキングをより一般的に(おそらく /about 下に?)用意することも提案します。
これは、売買に利用されるフォーラムにとてもぴったり合うかもしれません。
どう思いますか?さらにアイデアはありますか?
では、
イスマエル
取引をテーマにしているコミュニティなので、ぜひ使いたいです。
以下はご活用いただけるシステムです:
これに似たものを作った人はいますか?
いいえ、そうできたらいいのですが、まだです。トピック評価プラグインはあります。私のウェブサイトでは、各ユーザーが特定の取引セクションに取引リストスレッドを1つ作成できます。その後、他の人がそのスレッドに評価をつけることができます。
@Bill、私たちがどちらも求めている機能の支払いを進めています。
@P2W コミュニティの方々が自ら動き出してくださると聞いてとても嬉しいです。プラグインの進捗はいかがでしょうか?
最新情報をお知らせください。ありがとうございます!!
あのセラー評価プラグインにもとても興味があります
進捗はありますか?
