Ist dies ein Diskurs- oder DNS-Problem?
I went through the installation on my Linux machine, I went thru the ./discourse-setup and all went well, it said it would take a few minutes for the bootstrap stuff to set up, I have my website setup to make the IP address of my VPS go to forum.origingaming.net I created that A Name around a day ago, whenever I go to my website it says:
# This site can’t be reached
**forum.origingaming.net**  is currently unreachable.
ERR_CONNECTION_FAILED
Is this due to me installing discourse wrong or is it an issue with my DNS?
‘A’ record looks fine … DNS seems to have propagated … the issue is on your server I suggest.
The HTML returned is showing some basic Ember.
Are you getting any build errors?
I haven’t got any errors
Should I try to rerun the ./discourse-setup and see if I get any errors?
Looks like there is some kind of firewall blocking connections on port 80 & 443.
are you sure those ports are open? where is your forum hosted?
I’m using SkySilk VPS, I’ll try to open those ports, don’t remember doing that
Ok, I allowed those ports via ufw, does that take time to update?
You allowed for incoming right?
It should be instant.
Though it still reports connection refused to me.
I did
ufw allow 84
ufw allow 443
In the terminal, is there something else I need to do?
It returned Rule Updated (v6) for both of them
What does it return with sudo ufw status
Status: inactive
(20 chars)
Should I enable it via sudo ufw enable?
So it’s not UFW! try contacting your customer support if they have some other network based firewall in place.
Ps: is your IP 64.190.xxx.xxx ??
Don’t complicate things by adding another variable, let it be disabled unless it is at least online.
Yeah my IP starts with that, I will contact customer support now, should I ask why ufw is disabled?
No, You should ask them if they block public connections over port 80 & 443 with some sort of firewall, and if Yes, how to allow connections to your IP/VPS?
Ok, asking right now, thanks for your help btw
I totally missed this, Apologies about it!
What are the outputs of:
sudo netstat -peant | grep ":80 "
sudo netstat -peant | grep ":443 "
It said netstat command not found
EDIT:
Installing net-tools rn so I can do i
EDIT:
Apparently I can’t post any more messages because I’m a new member, so I’ll just edit this
When I did the netstat for “:80 “ it returned nothing, same with 443
If the IP works but not the domain name it’s a dns problem.
Jay, not so sure … both domain and IP address are returning the same HTML for me.
