Ive kept a category private to TL3 and Ive had numerous people saying they cant view it but meet the requirements. I checked one and it under TL3 it shows he has all the requirements and says will be promoted soon.
Why isnt this instant and can we make it instant? Also I have the topics viewed requirement set to 1. But its showing 125 in the requirements section.
The job on sidekiq that controls the promotion of users to TL3 run once a day, so it is possible that users who have met the requirements are promoted only the day after.
You should first update the forum to beta 2 and see if the problem persists.
I’ve just changed the settings for the TL3 that are modified without problems.
If the problem persists you should try the safe-mode first, if it does not work you should disable all the unofficial plugins and do the rebuild only with the official ones.
Pouvez-vous résumer les actions à entreprendre ou les points à vérifier lorsqu’un utilisateur est dans le statut « bientôt promu » depuis plus d’une semaine ?
