Issues upgrading from 1.6.0.Beta10+9 to 2.3.0.beta6
Hi
I am trying to upgrade my discourse forum from 1.6.0.Beta10+9 to 2.3.0.beta6, using the “Click Here to Upgrade” option, inside the Admin panel
See this screen shot: https://www.intecons.com/AMB%2067.png
However, after doing some stuff for a while, it just hangs up at “Building Assets”, see this screen shot: https://www.intecons.com/AMB%2066.png
I am not a NGINX expert, just Apache
That’s why I am not trying to upgrade it using terminal window, but I have no idea now where to go from here
Any helps will be highly appreciated
Thanks
Ashwani
PS: Attaching the log which it has created so far. It’s here: https://www.intecons.com/Discourse%20upgrade%20log.txt
The error is probably happening before, we can’t see it in your screenshot.
Hi Joffery
Thanks for replying, that’s why I attached the whole log link too. It’s here: https://www.intecons.com/Discourse upgrade log.txt
Hopefully this helps
So your error is:
Sass::SyntaxError: Invalid CSS after "...le:none}:root{-": expected number or function, was "-blue:#007bff;-..."
Not sure it’s coming from Discourse, might be a plugin.
If you’re updating from 1.6 you’ll have to do a rebuild from the command line.
Hi Jay
Thanks for the reply
But how will my data get transferred if I do a rebuild from command line
Sorry, I am a newbie
Can you give me some starting steps
 cd /var/discourse
  git pull
 ./launcher rebuild app
You will not lose your data. I believe that you’ll need to rebuild twice because the first one will upgrade the database.
For $300 or year I’ll do command line upgrades when they are required. Redirecting…
Small addition. If you had an error through the admin interface, you will have a high probability of error through the console. In order not to risk it can be immediately disable all third-party plugins and make a rebuild.
Hi Jay
I get this
ERROR: Docker version 1.8.2 not supported, please upgrade to at least 17.03.1, or recommended 17.06.2
When I try to upgrade via console
Any help?
You think you can take it further from here?
Here is the full log of what it shows: https://www.intecons.com/result%20of%20upgrade%20through%20terminal.txt
How was this installed originally? What version of Ubuntu is this?
Assuming you have updated everything in apt and are running 16.+ then docker can usually be taken care of with:
wget -qO- https://get.docker.com/ | sh
If docker was installed from an old Ubuntu version it is best to
apt purge docker.io
(or widget docker it is) first. You can see what it is with
dpkg -l |grep docker
