JS plugins not loading correctly
The discussion revolves around an issue with JS plugins not loading correctly on a Discourse instance. The user rbrlortie reports errors such as TypeError: e.find(...).not(...).magnificPopup is not a function and TypeError: window.Chart is not a constructor, despite the plugins being loaded correctly in the Network tab.
rbrlortie mentions that the issue started after upgrading from Discourse 2.1.0.beta4 to 2.2.0.beta2 and that it affects core features like the /admin dashboard charts. pmusaraj asks for confirmation of the plugin files’ presence, which rbrlortie confirms.
xrav3nz identifies the issue as a recent change to loadScript not working as expected for subfolder installs and submits a fix. The fix is later confirmed to be in test-passed by xrav3nz, and rbrlortie expresses eagerness to update the instance.
Hi,
Since last week or so my discourse is having trouble loading JS plugins.
What is strange is that they are indeed loaded correctly in the Network tab:
I am getting errors such as
It seems that stuff getting loaded via loadScript("/javascripts/jquery.magnific-popup.min.js") are not loading correctly.
Discourse version: v2.2.0.beta2 +184
Does anyone have a clue as to why this might happen or steps to debug this? Thanks!
Do you mean from a customization or plugin, or are you referring to a plain vanilla install?
The front-end should be vanilla except for two script inclusions that aren’t causing errors.
Core features like the /admin dashboard charts aren’t displaying.
Is this on your local environment or on a live site? Also, can you confirm that you have the Chart.min.js and jQuery.magnific-popup.min.js in the /public/javascripts/ folder?
You can see it live in most posts, e.g. https://www.robotshop.com/community/forum/t/mini-sumo-at-the-next-ny-makerfair/33003/3
The file is there and you can see from the network tab that it’s loading: https://www.robotshop.com/community/forum/javascripts/jquery.magnific-popup.min.js
Hmm, interesting. There are no images in the topic you linked above, so I don’t see what’s triggering the magnificPopup call.
I am looking at our previous stable environment and it seems that those issue might have started to appear when we moved from: Discourse 2.1.0.beta4 → Discourse 2.2.0.beta2
Hey @rbrlortie, a recent change to loadScript is not working as expected for subfolder installs, but I have identified the issue and submitted a fix.
Thanks for the report, and I will let you know when it’s ready for update!
PR for reference:
https://github.com/discourse/discourse/pull/6474
Awesome! We are awaiting your go to update our instance. :grinning:
The fix is in test-passed :muscle: Feel free to update anytime now. Thanks again!
This topic was automatically closed after 4 days. New replies are no longer allowed.
