fefrei
(Felix Freiberger)
1
After rebuilding my site a few minutes ago, Discourse no longer loads.
I get this error in the JavaScript console:
I’m down to these plugins, and the error is still there:
- git clone https://github.com/discourse/discourse-spoiler-alert.git
- git clone https://github.com/discourse/discourse-data-explorer.git
- git clone https://github.com/discourse/discourse-staff-notes
Disabling all site customizations did not help, too.
I’m out of ideas, and my Discourse instance is down
I should add that I am running on the (latest) beta commit.
Odd, I just rebuilt both discourse.codinghorror.com and talk.commonmark.org to latest, and they load fine with these plugins:
- data-explorer
- docker-manager
Plus spoiler and staff notes are used here on meta.
What’s the default language used there? Any unusual site settings?
zogstrip
(Régis HANOL)
3
Can you try without the spoiler-alert plugin?
gerhard
(Gerhard Schlager)
4
Try removing the spoiler-alert plugin. It was updated today and I guess that change is not compatible with the beta branch.
fefrei
(Felix Freiberger)
5
That worked (I haven’t singled it out yet, but removing all official plugins worked).
I’m adding all other plugins back in to check whether this is really the cause…
This text will be blurred
Spoiler alert seems to be working ok here though.
fefrei
(Felix Freiberger)
7
But you are probably running tests-passed, right?
I see this is something for @tgxworld to look at.
fefrei
(Felix Freiberger)
9
I can confirm this is caused by the Spoiler plugin. Thanks a lot, @gerhard!
