The discussion revolves around implementing a “jump to next developer post” feature in Discourse. darix proposed the idea, suggesting it would be helpful in long threads to quickly find developer answers. codinghorror pointed out that visiting the group page or using the “filter” button after clicking a user avatar can achieve similar results.
However, darix emphasized the need for a more direct “jump to next dev post” feature, especially in extremely long threads. sam confirmed that implementing this feature would be possible through a custom plugin, but it would require significant work.
Later, MidnightCheesePizza revived the discussion, seeking guidance on creating a similar feature, “Jump to Next Tracked” post, inspired by Blizzard’s Forums. This feature would allow users to jump to the next post from a custom group, but the user needs help with custom code implementation.
I was wondering if the following can be done in a plugin already:
all devs for a project are in a group “Developer”
for long threads it would be nice to have a button for “jump to next developer post”. from the current post in the thread jump to the next developer post. would make it easier to find all the dev answers and skip all the complaint posts.
I am aware of that option but in this particular case the threads can get really really long at times and it would be really helpful to just have a way to skip to the next dev post.
now that they are using discourse i was wondering if this “jump to next dev post”, which on the old forums only worked for the first, could be implemented properly.
You can also do this by simply clicking a user avatar anywhere in the topic and pressing the “filter” button, which filters the topic to just posts by that user.
A common place to do this is at the top of the topic at the topic summary …
Воскрешаю эту тему также, так как я ищу именно такую функцию и пытаюсь воссоздать её на основе форумов Blizzard.
У них есть кнопка Перейти к следующему отслеживаемому, которая переносит к следующему «синему сообщению» в теме. Я предполагаю, что это просто кнопка, которая переносит к следующему сообщению от пользовательской группы, которую я настроил в предыдущем посте, но поправьте меня, если я ошибаюсь.
Просто ищу небольшую подсказку, так как не знаю, куда размещать такой пользовательский код или их атрибуты. Спасибо за ваше время и внимание!
