Cool, you might like this in-progress ālanding pageā that has been whipped together from a category and tag group. It is working pretty well. Nothing fancy, but works.
Nice! Itās using this plugin?
No, created with Vue and uses Discourse API.
Hello, trying to use this but when importing a ZIP I get an error.
Doing this because i need the .css file and .js.
See: Landing Pages Plugin š© - #47 and the tag end-of-life
@angus is it possible to use bootstrap for creation of main page (login) page of Discourse instance?
Thank You ![]()
I think weāve had a report of this plugin hiding the sidebarās Edit Custom Section modal:
Iāll move the tag over to broken. ![]()
Iām happy to say that @cabidop has breathed new life into this plugin. It is no longer broken
. See further
Thanks for the mention, @angus ! Happy to help with the plugin, I will be around here (and also on Github) so feel free to reach out.
Hi.
Does the plug-in remain functional, with Blog landing pages as of today?
Iām new to the whole thing & when I try it, it installs & when I follow the docs (ones I found) I get an error about ābodyā (which I found no mention for) which I leave as is, empty.
Perhaps I missing something obvious & trivial.
Hi, @lejeczek! I wasnāt testing the Landing Pages Blog repository so I donāt know if itāll still be fully compatible, but thereās definitely a bug in this plugin that prevents the blog pages to load.
Iāve just pushed a small fix for it, once itās ready to use Iāll let you know.
The fix has been merged ![]()
Please help, site got messed up from this Plugin
I am trying to use Landing Pages. I installed plugin on my server, but the only 2 config options for it in my Admin panel are:
I was following the instructions on his site to setup a Blog-looking page. I installed the plugin, installed the Blog Landing theme, and the last step is āSet up the Blog Landing Pages as your landing pages repository.ā Well, that ālanding pages repositoryā URL is broken, so Iām stuck. Iām not sure how to implement the landing pages because I have no config options from the Landing Pages plugin itself. @angus?
As this is a third-party plugin, youāll need to ask support questions on the topic itself. Iāve slipped your post over to get the right eyes on it.
Ah, ok, was wondering why my post got locked when I refreshed my page, haha. Thanks. Hopefully I hear back soon!
I believe this is this one:
If you need āASAPā you may need to be prepared to contract a professional. Our community support is great, but itās not āclick your fingers and always get instant support for freeā. ![]()
Hello @45thj5ej
Could you explain what you mean by this?
Any idea if this is also outdated? An instruction there says, " To connect your pages repository, go to /admin/plugins/landing-pages and click Repository"
Nevermind, figured it out while typing this up. You literally have to go to
https://yoursite.com/admin/plugins/landing-pages. I kept thinking I had to go to Admin > Plugins > Landing Pages settings icon, which would make the most sense. Sheesh. Thank you for your reply!
I think we are all good now, but I do have a question: Instead of using the blog theme (GitHub - paviliondev/blog-landing-theme), can I use my own theme that Iāve always used?
