Language Switcher Problem, Not Translating Posts
Hi everyone, I enabled Language Switcher and set all the parameters and settings exactly as explained in the tutorial, unfortunately it only translates the words of the forum but does not translate the text of the posts, so the text of the posts remains unchanged in the default language, why this problem?
Are you trying to translate posts from System Users?
Yes, like on this site, you put Chinese and it shows you the posts in Chinese, put French and it shows you the posts in French, etc… I tried to activate the Language Switcher but unfortunately the translation for the posts doesn’t work, I want to do it like on this forum!
Automatic translation requires Discourse AI configured and enabled with a LLM available for translation. Did you do all that? Can you share a screenshot of the page at /admin/plugins/discourse-ai/ai-translations ?
no,i don’t even know this setup existed, so… after I configure discourse-ai I also need to enable the language switcher, right? In case of any errors with the configuration, I’ll send you a screenshot.
Here you will find all the steps for configuration
